Hey all,
New to the forums and was just trying to find out if there is any cruises coming up in Hills District area? Quickly saw the the Hornsby/Central Coast cruise and didn't really get a chance to read it properly and had trouble trying to find it again!!!
If thats still a weekly thing would be interested in some more info on it as I'm keen on joining in!
Cheers,
Krafty
https://www.sau.com.au/forums/topic/280320-any-upcoming-cruises/
