http://www.blazt.biz/information/cars.php
lists V35, but im guessing thats a yankie V35, different to the JDM variety??? i talking consult-wise :thumbsup:
I tried this one on my car and it sees the RPM and can turn cylinders on and off to test them but beyond that it does no more.
This system works perfectly on the v35 but as this car was sold as an Infinity in the US I am sure this is why it was designed to be OBD2 compliant.
Our car was never sold outside Japan so this is why the porblem.
Berwick Nissan also gave me about 300 questions when I wanted a new keyblank for the Skyline...
Told them it was for a Micra, and even gave them a Micra vin.. that shut them up...
This is so short sighted of them not to take our money... Toyota went through the same thing with not wanting to touch the imports, then the penny dropped about how much Soarer owners are prepared to pay for servicing and parts... Toyota NZ even import and sell Grey import vehilces through their Toyota Signature scheme..
Haha! Berwick were actually more than happy to take my money ($97 per hour), but stated clearly that they refused to put their Consult on my car and would treat it as if it was a Falcodore...
I promptly called FTG Nissan from Berwick Nissan's phone and booked the car in.
consult 2 or 3 will work you rekon?
Yep.
FTG hook up M35's and V35's to their Consult 3... no problem.
Consult 3 FOR SALE!!
Don't fight over it ladies...
The Toughbook CF-18 is nearly $6kAUD by itself.
That package is a bit too rich for the privateer though...
All UDM cars have been mandated for OBDII since around 2002 I think, and most are now CANbus. KWP is fairly popular in JDM cars, but don't hold your breath about compatibility. For example, my inlaws' MY99 Forester GT has the OBDII connector - and doesn't talk any languages except genuine Subaru. :P
lists V35, but im guessing thats a yankie V35, different to the JDM variety??? i talking consult-wise :angry:
Blazt are in NZ, and he lists the V35 tested as being a 350GT? So most likely tested on a JDM car. But it will be one with the VQ35DE, not the VQ25DET used in the Stageas most of you have - wonder if it is different?
It is definatley different. I have tested the Blatz gear on the M35 and it does not work.
Whilst the V35 is a JDM car, the same car was exported as an Infinity G35 to the US so you would have ti imagine that if all the G35 for the US are going to be ODB2 compliant they would use the same system in the JDM cars rather than creating a new platform just for this car.
Cheers
Andy
Im pretty sure you would have to run all the v35 computers to get it to talk. Too hard basket. Only option left is the Greddy info touch which apparently works on m35 and can reset some cars, probably not ours tho. If there is any info or programs that work, I cant find it. Surely someone in japan has cracked it.
:thumbsup:
that reads it :thanks:
and its B'tooth!
as does this :)
(not the best image of it but it will do.)
the top one is a LOT cheaper than the main X431. and if you keep it updated does 99% of what a C3 does
for the diagun loaded its $3600ish with a few manu's missing.
Edited by Chris Rogers
  • 1 year later...
Did we get a complete answer on if the M35 is OBDII or not?
Just found this on the net, and thought it looked interesting...
ecoRoute HD
Trip computer info for those without the factory tv/nav... oh, and it's a sat nav..:thumbsup:
ecoRoute HD
Does not work on our cars... :(
  • 1 year later...
I know this has been covered (probably to death) but I have just bought a GoPoint Technology Cable GL1 www.gopointtech.com to connect my PNM35 to my old iPhone. I was hoping I might get lucky seeing as though my Stagea has the VQ35DE which the US Infiniti G35s have and also it is a bit newer, 2005.
Anyway, for any of the apps to first begin even trying to talk they need a power signal. After testing all the pins in the OBDii port there's no voltage on any of them when the engine is running. Should there be power and is there a fuse or something I need to check, or is it simply that the OBDii port pinouts are different.
I tested the cable on my brother's Yaris (yeah he's not exactly a car enthusiast) and it works great. I put a multimeter on the pins of the Yaris' OBD2 port and a few of them showed almost 12 volts and one (I think Pin 16) had almost 14 volts with the engine running.
All I am after is a simple computer to display basic parameters and in particular mileage. Also the engine check code thing would be good. If this doesn't work, I am going to look into the ECUDatascan www.ecudatascan.com.au which apparently works on R32s to R34s, Silvias etc.
Cheers
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
