FOR SALE or TRADE : R34 GT NA COUPE
Make/year: Nissan Skyline 1998
Model: R34 Series 1 - 2.5 litre GT NA 2 door Coupe
Odometer: 62xxxk's
Transmission: 5spd Manual
Colour: Silver (Code KV2-athlete silver)
Complied? Yes -in mid 2006 - all compliance paperwork will be provided to buyer
RWC supplied? Yes, if needed, at purchase
Currently registered? Yes
Price: $17,750 - may trade/swap with Holden Rodeo / Nissan Navara/ Jeep/ other similar incl 2WD or 4WD variants 2003 on - if you have a possible trade pm me
Contact: Anthony - definitely prefer you pm initially as I don't want long calls at inconvenient times delaying other calls from friends and other people I need to hear from - or if you need to fone: mob 0417- 066617 - pls not after 7 p.m. - and no private numbers will be answered - maybe include an email address in your pm to ensure a quick reply as there are SAU time restrictions applied to the number of outgoing pms a member can send and this may delay a pm reply to you from me - if your not an SAU member already then join so you can pm
Conditions of sale
Payment by bank checque
NO Test Pilots - conditions may be applied to weed out time wasters etc. - so if you have from 15 to 500 questions your probably not ready to buy a R34 Skyline so either don't call at all or pm only if you must
Any mechanical inspection is OK but will be at buyers cost.
Comments / Features:
Car is second car not a daily driver, is always garaged and used weekends etc. Body/interior trim/paint and mechanical is all in very good to excellent condition. No accident damage ever, no rust or corrosion or other blemishes and all glass in as new condition.
Bought this coupe about three years ago with 54XXX km on odometer - only done another 8,000 km since - fully serviced car at 59XXX km.
Features - the following list of items either came standard or were installed as options at Nissan factory or by first owner in Japan, except where noted -
all the usual power/luxury options - windows /mirrors/central locking/remote key doors and boot opening etc etc
ABS brakes
dual SRS airbags
Series 1 - so has the drivers side seat belt extender
5 speed manual transmission / 4.3 diff ratio
16" std Nissan alloy mags with 205/55/16 tyres fitted new at compliance (so about 75-80% tread still remaining)
Climate control air conditioning
3 position adjustable headlights - switch is on rhs bottom of dash
Xanavi tv/sat nav/cd player with pop-up screen - functions perfectly - this unit is capable of taking video feed to play movies from an external dvd player
AM/FM radio and cassette player
Altise (Aero) kit factory fitted body with genuine Nismo adjustable (for angle) rear spoiler - very few of these genuine adjustable spoilers are seen on R34s in Australia
Nismo after market oil, radiator and petrol filler caps - some Nismo stickers on windows (each side) too
Blitz fuel pressure and vacuum gauges - fitted on A pillar area
R-Spec Turbo timer - yes! a turbo timer on a NA engine - the first Japanese owner had it fitted and it functions just as per standard - its fully adjustable for time settings of course and/or can be turned off
Kakimoto 'Super Race' stainless steel exhaust - sounds great and fully compliant with noise regs
upgraded ignition system -Splitfire coilpacks (6x) fitted by me @ 58XXXX km, together with new set of spark plugs at same time
engine runs perfect - first start every time - does not blow any smoke or use oil, has excellent compression and consistently gives 9.6 ltr/100km average consumption
just transfer rego and drive and enjoy - needs no work to be done or money to be spent
** PLS NO JOY RIDERS or TIME WASTERS - SERIOUS BUYERS ONLY **
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
