Car has been going perfect ever since i bought it at the end of last year.
Has all of a sudden today started playing up, the 4wd light on the dash has randomly appeared and wont go away, the abs light is also coming up and wont go away either, the car has obvioulsy faulted inot 2wd mode as there is no sign of torque going to the front wheels at all on the stock torque gauge.
Have taking the car to nissan who have plugged in a consult II, only error code they can find is "ETS Valve", which they are not sure what that means, so are going to do a bit of reasearch and get back to me.
Anyone have any ideas on what it might be, we were thinking possibly a wheel speed sensor since the abs light is coming on aswell, but from the fault code it sounds more like an attessa pump??
Any help would be great.
https://www.sau.com.au/forums/topic/280375-r33-gtr-4wd-light/
my manual says that
ETS F/S VALVE has several fault conditions:
* valve control terminal voltage is abnormal (open circuit)
* valve control terminal voltage is abnormal (short circuit)
* when fail-safe valve is being controlled to OFF it turns ON
these are the only ETS VALVE related issues.
a lot of these error conditions they light up both ABS and 4WD and the whole system goes into failsafe mode.
later in the manual, the "valve" is referred to as a solenoid: the "e-ts fail-safe solenoid" and perhaps the ecu
no longer has a good connection to it, or the solenoid is burned out.
Did you look at your atessa ecu after a drive of 30kmh for a minute then stop (not engine) and find
a LED flashing on the atessa ecu in the trunk. Long flashes are 10s, short are 1s. Code 12,23 might be
long,short,short .. long,long,short,short,short ...
depending on the code(s) flashed, you can find further things to check..
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
