hay dan here new to all this im looking at doing a 2 wheel drive manual conversion on my s1 stagea using R33 box and flywheel and make a 1pc tail shaft.
exedy cushion button clutch
remove and modify front diff and drive shaffs to suit 2wd and mod plate so drive in 4wd auto and drive out 2wd and 5 speed.
is $5000 to much to pay??
https://www.sau.com.au/forums/topic/280429-2-wheel-drive-manual-conversion/
I'm no expert, but why wouldn't you just sell your car and start with a Stagea RS, and just do a manual conversion on that? saves all the reverse engineering...
*edit* Actually, thinking about it: it's waaaaay easier to find brake and suspension components for the RSFOUR, and I believe the RWD cars were all S2(?), so it may be better the way you're thinking...
I could do it for less but thats a fair price for what you want. I would not use a 1pc tailshaft.
$5000 is a very fair price
My AWD manual conversion cost me $3000 in parts with r33 gtr box only costing $800 and s/hand manual console (very rare to find) $650 and clutch $850.
Your conversion
R33/R34 manual box $1200-1500
New Console approx $1000
New clutch $500
Clutch pedal, brake pedal, hand brake and all the bolts etc needed $500-700
Does not leave too much for all the labour to do the conversion and the sump mods.
um, apart from the car feeding power away from the driving wheels when they lose traction?
not much i suppose....
just sell it for a 2wd version. manual will be much easier to fit and you wont be draging the extra 200kgs that you dont need around with you.
Anyway the tailshaft would hit the floor when your suspension compresses this would be worse if our car is lowered.
How would that occur when the diff is attached to the subframe? if we were talking a live axle car,that might occur,but not in an IRS nissan.
the only movement the driveline has to deal with is engine twist and a little vibration.
Justin...
weeeell....not if you pull the 4wd fuse as well
personally I don't see why cvs are a problem unless something else is stuffed. cv boots should last 50-80k, and cvs joints themselves for the life of the car
Justin...
i thought the same thing when i read it
good luck with the conversion if you go ahead with it!
  • 5 weeks later...
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
