hows this build coming along ?
Hi
The cars coming along very well, just finished getting all the sound deadening out and cut the rear parcel shelf and wall out, and cleaned all the imperfections out, it look very nice. Construction of the cage will begin very soon, still tossing up the idea to stitch weld the chassis and add more bracing in the cage.
As far as engine goes, ideas change like the wind, but most likely be running a JUN bottom end (maybe), also would anyone like to swap, I got a Brand New Trust T88 Mainfold with new 50mm Trust Waste Gate Never Been Used want to swap for a HKS T51R V-Band Manifold and a 60mm Wastegate.
I Have just order a heap of carbon goodies for the car to make it look the part:
-Carbon Grill
-Carbon Front Diffuser (Abflug Style)
-Carbon Rear Diffuser (Top Secret Style)
-Carbon Tomei Style Headlight intake.
More Pics coming soon.
Cheers
Benny
This is a very nice project.
Love to see some more pictures.
The only Achilles I can see in your setup is the gearbox. It will get you in the 9 but be very difficult to get into the 8 with it.
How fast has Mark and Paul done in this box?
Theo Woollett, got into the 8 with the ppg dog box, but it took him a very long time. His gearbox maintenance bill, if he was not sponsor, would have been very big too.
While you are still at the drawing board stage, it might be worthwhile to think about a sequential gearbox (OS88 or Hollinger). It will save you a lot of money and heart ache in the long run.
That was my 1st thought aswell
I didnt think there was much difference in HP rating between the 38gk and T62r
The 38gk is an 1100hp turbo and the HKS 1200hp
Either way I doubt either would be big enough to run 8's in a GTR
huh ??.... reece mcgregor used a T51R SPL to run 7's
althought this wasnt using radial tyres... "Dunlop SP Sport Dragway Special Tyres"
Hi Guys
Here's some quick update pic's, cars nearly finish the stitch/tac weld stage, rollcage commencing next week. Also new carbon parts should be arriving today or tommorow.
Cheers
Benny
Hi Guys
More pics of the carbon goodies that turned up today, i would like to give a big thanks to John at Rota Australia for his great Service and Help.
Ordering Soon:
-Carbon Boot
-Carbon Doors
-Carbon Prop Shaft
Cheers Benny
  • 1 month later...
  • 4 weeks later...
Hi Guys
Ordering Soon:
-Carbon Boot
-Carbon Doors
-Carbon Prop Shaft
Cheers Benny
Whered the diffusers come from?
  • 3 weeks later...
Quick Update,
The car is coming along great, our initial completion date was January, but you know how these things go delays, waiting for parts and have not had the time off to do anything. Anyway rollcage has been given to a professional welder, looks awesome will be stiff as a board. The Custom Jun Stroker kit arrived this week along with some Jun Hi-Step Cams, so engine will hopefully be done very soon (cant wait). The problem we have at the moment is the interior, we cant decide whether to carbon overlay everything or flock it. I wanna go with carbon, it will just take ages to do thats all.
Possible Parts Update list:
-Wilwood Front Brakes & R33 GTR Brembo Rears
-Full Ikeya Formula Suspension setup.
-6 Boost Manifold & HKS 60mm Wastegate
-Whiteline Swaybars
-Plus much more
P.S needs coilovers for car for drag setup HKS Drag Coilovers would be nice, if anyone has any for sale, also chasing a 3.5" or 4" titanium or stainless catback exhaust.
Also will someone please take this Trust Manifold and Wastegate of my hands!!!!!
http://www.skylinesaustralia.com/forums/Tr...12#entry4911612
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
