Hello,
Another Update.. sorry has been awhile, Most of our time has been spent installing the Vipec V88 and the M&W CDI. As the majority of the wiring system is now run from the V88.
Exhaust has been fully installed, just looked at plumbing the Wastegate screamer back inline with a 2" V band clamp.
All braided Fuel lines are finished and has been pressure tested for leaks.
4" HKS Drag exhaust, full stainless system with Removable Titianium Cannon.
Inline Return Fuel filter (silver)
Inline Oil Filter for Prelube system (black)
Fuel lines Clamped alone Chassis
Braided lines on Powersteering system.
Prelube pump now mounted under Car due to ANDRA rules.
Vipec V88 Installed under the dash, also with a low water level alarm.
M&W CDI system installed on Ruber mounts.
Custom Intake on Turbo with HKS 4" Pod filter. Using no clamps,
Power Steering Tank with Braided Lines, Note.. the wiring for the injectors and TPS laying there is the last to finished.
Custom Made Crank Trigger and Trigger Mounting.
EGT's Installed in every cylinder
Morroso Line lock switch mounted on Works Bell Steering Wheel.
This is a very impressive build to say the least. I jump on here and check atleast once a week to see if there are any updates.
Out of curiosity are you planning on running this thing at the strip in Mackay? if so i am making the drive down from Townsville to see it run lol
Looking good, I love the way you have mounted the fuel cell.
WHat coils are you using for the M&W Cdi?
We are using Spitfire Coils, they are not recomended to run with the CDI, but if we run with the CDI coils the Center Coil cover will not fit back on..
what pump are you using for pre-lube?
Ours is the EP4 Varna Pre Lube pump.
http://www.varnaproducts.com/EPPump.php
cost us around $600 Aus when the dollar was shit, so it would be alot cheaper now.
- on 12volts can flow 6.6LPM at 60psi.
- on 24volts can flow 15LMP at 60psi
Cheers mate, Yes this car will be at every event next year in mackay.. hoping to get enough practice under my belt for the Jamboree next year and chase the record of (worlds fastest Manual H pattern GTR in the world, currently Theo W .. 8.95secs) definately not and easy task.
thats a crazy amount of earls fittings, farout that woulda cost alot
Haha yea it was, im not a fan of silicon and bulky clamps. Thats why we have decided to run with all braid and solid mounts for the Adel wiggins clamps. Braid price on this car goes well over the 10k mark.
stock gtr wheels, avatar is just a pic.
wonder if you could dye the filter purple without affecting its flow characteristics?
Haha, f**k no i hate the green too. I bought that filter at the 2010 Jamboree very cheap, I am buying a purple one they are only $30 bucks off ebay for the replacement filter.
would you consider not running an air filter?
Not a chance mate, When u pay $6000+ just for the turbo we are definately running the pod filter. Have alook at what happens if u dont run a filter. It Wears the blades down.
check out NENGUN. They are having huge wheel discounts on rays this month only. up to 44% off I think they said. Plus the aussie dollar to yen isnt too bad atm either at 80yen
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
