definately not a holinger, or a sequential, cost way to much money. They are weaker than Straight cut dog box, because they are helical cut dog engagment,
but yes the next option would be a liberty, but at the moment I want to keep it like a streeter for a bit longer haha
All other things being equal helical gears are significantly stronger...
That last pic looks like it almost has the front wheels off the ground
..what a car :)
The way the car was launching it felt like the wheels where coming off the ground :) the suspension is working exceptionally well and cannot complain with 1.35 and 1.36 60foot times, I think with a little bit more launch HP I could get it down to a 1.25-1.30 maybe.
i can never get enough of this white ghost :) - surely u have a nickname for this car?
good video compilation
Havent got a nickname yet, maybe people will have to give me ideas...
OS giken Samwage plate turned up yesterday, just gota get the new parts for the gearbox and its ready to go back together :)
Good stuff!
Where did you get it from and what price did you get it for? (PM if you like). It's a heavy fooker!
Give me a yell if you guys need a hand with anything. I'm stuck on my project... Waiting on the motor to get here.
I don't think you would handle the pressure in our shed, a lot of F this, F that, your a Fing Fhead, tools get thrown, people storm out, 2 many chiefs and not enough Indians, a lot of head butting going on.
I always offer to help you out, Callan... I think. :S
That doesn't bother me, man. I'm a Splicer/Fabricator. Sounds like a normal day at work. Haha.
Nah I just wait till your hungover/tired before i want you to do anything haha :P
Good stuff!
Umm bought it from some fella off SAU, 2nd hand for $600. It's definitely a lot stronger than standard.
Hi Guys,
My titanium tubing, round bar and V band rings have arrived. Just need to buy a cold saw and start fabricating my exhaust :)
4 Inch exhaust tubing
2 Inch tubing for screamer pipe
14198_4910515367827_1597064001_n.jpg\
titanium 8mm round bar for exhaust stays, 25mm round bar to turn out exhaust fittings for AFR and EGT's, and a bundle of TIG wire.
Titanium 4" V band exhaust ring ( worth a shit load )
44mm Tial Wastegate V band ring, keep for drift car screamer pipe.
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
    • Also, if you're into customizing your ride, you might want to check out tesla accessories model y for inspiration on screen integrations and functionality.
