Amazing work Ben, builds like this inspire me. Quick question, it appears you have a gloss finsh on the dash with the carbon fibre and a dry finsh with the centre console ( may just be the lighting ) Is there any tips to get the dry finsh ?
Cheers,
The pic must have been taken before we put the resin on it when it was sanded back, all of our carbon parts have had a clear coat of resin on them, not really sure how you would make it look like dry carbon.
Hi Guys,
Started the car today and had a few issues but eventually fired up. The Bloody Crank angle sensor shit itself so lucky mark had his old one from his GTR. Also had a Voltage drop on our injector supply and was only getting 9volts instead of 11.5volts and would not fire the injectors. Once the car was started we shut it down fairly quickly cause the V band clamp behind the turbo was leaking and we will buy a new clamp in the morning and chuck the car on the dyno. Here is a video enjoy!
are you going to put more boost into it?
also how did you run the motor in if its just been finished and put together?
i know with my motor they wanted me to do 2000 kms before having the full tune completed
Sorry guys had a miss print the end result for today was 800Hp at all 4 wheels @ 26-27psi @ 9000 rpm which approx 1000 flywheel hp, dyno sheet and videos will be put up as soon as i get home got a 12hr drive now yucky.gif, we ran the motor in on the dyno for about 50km on 98ron fuel than upped her.
50kms is enough time for everything to bed together?
Also from what I've read and been told by my own engine builder, you shouldnt run motors in on a dyno.
Not saying you dont know what your doing just going by my own experience.
There are a number of shops who do 50k's or so after a quick drive around the block to make sure of no leaks, then turn it up and give it back to the owner at full power :)
Mine was done like that, installed and started, check for leaks, 100k's of run in then booked for the dyno
yeah 2,000kms to run in before power tune is a waste of about 1,800kms in my opinion. but given I didn't build your engine you did the right thing in taking their advice.
also I dunno what's wrong with running in the engine on the dyno? it's fantastic. you don't have to go anywere, you can vary load and speed as you like. no time spent at red lights etc idling. no time spent on long constant speed and rpm sections of road, can run up to whatever speed you like, and since you are not driving you can keep a much better eye on the car temps etc. it's the best way to run it in in my opinion. but would get a bit expensive if you wanted to do 2,000kms of it!
well i was just going by what croydon told me to do,
they build heaps of motors and know there shit so i took there advice.
but yeh i guess everyone is different as to how they do things
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
