Hi Guys,
Here is another video I found that somone has took on the 9.7sec run from the hill at palymra,
The sound is just awesome Ben, LOOOOVE it! :D
That gear change to 4th was absolute lightning fast as well.
Yes 3rd to 4th was ridiculously fast with this ignition cut, hopefully when we take the car back out in 2 weeks time, we will be trying to flat shift every gear with no clutch. Plus alot more boost and timing.
  • 3 weeks later...
  • 4 weeks later...
Only got to see one of your runs at the king of the hill on Saturday. But didn't catch the times you ran. 9.5 something i thought i heard. Looked really strong. Was keen to catch up with you guys for a yarn but had to bail early.
Up until you guys came up I had the gtr track record up here in Townsville but you sure gave my 10.7 a fair touch up. Haha. Mine is set up for Tarmac rally though..
Top effort. Might catch up with you at prossie drift when you get that 13 finished.
Coop.
Yeah sorry about taking your record Coop my bad lol, there was suppose to be a meet on at Palmyra that weekend but it was cancelled, and we wanted to more testing before Jambo so we decided to come up to Townsville for a run. We ended up getting a 9.5sec pass @ 144mph with a 1.4sec 60ft. The track conditions were not the best put we were still impressed with the times considering we changed nothing to the car besides the rev limiter which was but out further and changed driving style. Looking forward to Willowbank to see what times we do on a really sticky track.
We did also have our first mechanical failure, but was to be expected poor old clutches don't last forever, so it has been pulled out and sent to Doug at NPC to do his magic. Which will be great to have a fresh clutch before Jambo. I will post up some vids from townsville when i get a chance.
Yeah would be great to catch up with you Coop may see you out drifting my 180sx is still gonna be awhile yet but when it is, gonna be freaking awesome fun.
Here's some pics of clutch that's had a hard life:
8.7 - 8.8 sec is the goal which is what we are aiming for a Jambo this year. A retune to 36psi + maybe a bit more (currently running 27psi), put rev limiter to 10500rpm (currently 9000-9500rpm) combined on Willowbanks Super Sticky Surface it will be very possible. Just from changing from Palmyra to Willowbank should give us 0.5sec gain straight up.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
