Hi guys,
got the car wheel aligned today here in brisbane from bridgestone select, done an awsome job. We settled for Rear left +1.14degree Rear right +1.29 and both toeing in 2.7mm which under full squat the car will pull the rear wheels back to 0 degree and 0 toe, so should hook up good.
Front left -1.83degree and front right -1.46degree, front toeing in 0.8mm and got the caster sorted aswell, because the left front was hanging back the right front was pushed foward, so thats all good now too.
I am a little worried about the amount of toe on the rear as it does seem like alot.
After looking at that video, it doesn't look like your getting enough rear droop to zero out your ass end after the initial launch... Spring rates, compression and weight transfer looks pretty good though.
I'd hate to see the car start getting sketchy in the top end for the sake of marginally more traction (that you may not need).
Must be a blast to drive!
Justin.
The Japs were going faster in the late 90's with H-patterns?
They probably were...it's been a while :)
Definitely fastest/quickest H-pattern street GTR either way.
Looks like there is plenty left in, too.
Hi Guys, Just driving home back to Mackay, I will put the link on the 8.97sec pass up. Also Theo Willot Still holds the World record for fastest H pattern GTR I missed out by .02 of a second, and on Sunday I was gona to smash that time with an ET of 8.8. But third gear smashed into a million bits. I was 3MPH faster by half track than my 8.97 and thats also lifting of cause 3rd blew up. We are under the impression that the selector fork has bent therofore only half engaging 3rd and stripping the teeth off the cog.
Im laying down the challange that this car will run a Mid 8.5sec pass or lower with this H pattern box, as I am only running 150MPH to get 8.97secs and theo done 8.95 at 162MPH, I am only currently running 900-950HP with alot of go juice up my sleeve. Haha.
I will upload the other video my GF filmed later tonight when we get home,
cheers Matt
There is no evidence of a Japanese or American or euro or pommy GTR even running the 8s with a H pattern box, me and theo are the only ones to do it, Yes there are plenty of GTR in the 8s and 7s but they all run Sequential boxes or Airshifted liberties or Lenco gearboxes, which are an easy 0.3 of a sec quicker. Thats why Theos time is a World record that himself or me could ever find recorded.
Yes, how could I forget Theo's time....I don't think it was registered though :D
Either way, fantastic result and hope to see it get close to [RH9GTR]'s 8.47 auto time
btw, what does the car weigh in race trim?
Check out these videos... There are several running 8's with H-patterns
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
