All them Jap cars are running full drag slicks and are far from street registered, still impressive for the time period back in the day. Fair bit of difference between say 17" Mickey T Et streets and 15" Hoosier Drag Slicks
No doubt!
I was just mentioning it so people didn't make wild claims and look silly :)
Your car is massively impressive!!!
Awesome effort on breaking the 9 sec barrier!
It looks like you did it a hell of a lot easier than the guys in that old Jap footage... Even with the help of slicks a couple of them were fighting the car the whole way down the track. By comparison your pass almost looks boring - so it shows how much better your suspension and aero setup must be.
Maximum traction on take off, u can actually see the tyre marks u have left like a mini tramp...is that expected with your power level?
Also, why did u decide to stick with the 2.6ltr capacity?
It's a JUN 2.7 mofo :D
Hi mate, we have a JUN 2.7L stroker but swapped the oversized pistons for a brand new set of standard bore size CP pistons, its still retains 2.6L, and why 2.6???? because they rev hard and for some reason everyone thinks more Capasity is better. But not for what we want to do. 3+Litres are just slow reving and sound like shit.
I agree with u 100% that the 3ltr is slower revving and don't sound anywhere near to that of a 2.6 - I can make this statement as I've had both...2.6 all the way :)
Amazing Ben! Will watch videos when i get home for some more ear porn oooh yeah :D
Sucks about the gearbox, tends to happen though when going as hard as you are.
What is the next event you are aiming for?
They probably were...it's been a while :)
Definitely fastest/quickest H-pattern street GTR either way.
Looks like there is plenty left in, too.
Ah the old term "street". :laugh:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
