definately not a holinger, or a sequential, cost way to much money. They are weaker than Straight cut dog box, because they are helical cut dog engagment,
but yes the next option would be a liberty, but at the moment I want to keep it like a streeter for a bit longer haha
All other things being equal helical gears are significantly stronger...
That last pic looks like it almost has the front wheels off the ground
..what a car :)
The way the car was launching it felt like the wheels where coming off the ground :) the suspension is working exceptionally well and cannot complain with 1.35 and 1.36 60foot times, I think with a little bit more launch HP I could get it down to a 1.25-1.30 maybe.
i can never get enough of this white ghost :) - surely u have a nickname for this car?
good video compilation
Havent got a nickname yet, maybe people will have to give me ideas...
OS giken Samwage plate turned up yesterday, just gota get the new parts for the gearbox and its ready to go back together :)
Good stuff!
Where did you get it from and what price did you get it for? (PM if you like). It's a heavy fooker!
Give me a yell if you guys need a hand with anything. I'm stuck on my project... Waiting on the motor to get here.
I don't think you would handle the pressure in our shed, a lot of F this, F that, your a Fing Fhead, tools get thrown, people storm out, 2 many chiefs and not enough Indians, a lot of head butting going on.
I always offer to help you out, Callan... I think. :S
That doesn't bother me, man. I'm a Splicer/Fabricator. Sounds like a normal day at work. Haha.
Nah I just wait till your hungover/tired before i want you to do anything haha :P
Good stuff!
Umm bought it from some fella off SAU, 2nd hand for $600. It's definitely a lot stronger than standard.
Hi Guys,
My titanium tubing, round bar and V band rings have arrived. Just need to buy a cold saw and start fabricating my exhaust :)
4 Inch exhaust tubing
2 Inch tubing for screamer pipe
14198_4910515367827_1597064001_n.jpg\
titanium 8mm round bar for exhaust stays, 25mm round bar to turn out exhaust fittings for AFR and EGT's, and a bundle of TIG wire.
Titanium 4" V band exhaust ring ( worth a shit load )
44mm Tial Wastegate V band ring, keep for drift car screamer pipe.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
