ok guys ive just finished putting in a new rb20 and i got a whole heap of spare engine parts.
things will go fairly cheap as i would rather seel them than throw away.
-rb20 AFM $60
-all 6 injectors $40
-machined flywheel $40
-Brake master cylinder $30
-manual starter motor $20
-RB20 turbo $50
-Engine mounts $30 for both
-cams Intake and exhaust $50
-cam gears $20
-rocker covers $15 for both
-RB20DET ECU $80
-RB20DET coil packs $60
-brand new hicas lock bar $50
-R32 series 2 gauge cluster (86 000km's) $80
-CAS sensor $20
-Clutch fan $10
there is more stuff laying around so if its not listed there is a chance i may have it PM or call me on 0403 329 579
Edited by libardi
https://www.sau.com.au/forums/topic/280434-rb20det-engine-parts/
  • 3 weeks later...
-rb20 AFM $60
-RB20 turbo $50
-cam gears $20
-RB20DET ECU $80
-CAS sensor $20
-Clutch fan $10
Is that a cam sensor for $20 ?
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
