This is my slow build up.
In early 2007 i purchased a 1999 R34 GT-four manual non-turbo through Iron Chef Imports. It had done 74,000k's and was stock as a rock.
When he found me the car i thought of doing a whole GTR four-door, and that where it leaves me today.
So far:
Performance
-HKS 3" cat-back
-Blitz pod
-Nismo fuel pump
Handling
-Cusco Zero 2E coilovers
-Cusco front strut brace
-Cusco front upper camber arms
-Cusco Front caster arms
-Cusco Toe arms
-Cusco Rear camber arms
-Ikeya Formula Traction arms
-Nismo Sway bars front & Rear
Wheels
Work Emotion 18x10 +18 with Kumho KU36 235/40/18
Braking
-R34 GTR v-spec brembos
-ADR approved braided brake lines
-Cusco master cylinder stopper.
-Stock Brembo pads
Stereo
-JVC dvd/tv/cd double din head unit
-Focal front speakers
-Rockford fosgate rear speakers
-Digital design amp
Exterior
-Nismo clear side & front indicators
-Origin Japan Carbon Fibre Boot lip with welded holes and shaved brake light
Interior
-Nardi 330mm deep corn steering wheel
-Defi BF series oil temp, water temp, oil pressure, controller unit 2
-Superior Japan Carbon fibre air con shroud
-Superior Japan Carbon fibre shift surround
-Carbon fibre overlay door handles, cluster, kick panels, window a/c vents
-BNR34 pedals
-Nismo GT shift knob
Pretty sure thats it.
From now on i have brought
-Brand New HKS GTRS Turbos
-BNR34 Getrag
-BNR34 subframe with diff, hubs, shafts
-Trust 12row oil cooler with relocation kit
-2 Bosch 044 fuel pumps
-BNR34 wiring loom
-Tomei 044 holder x2
-R888 semi's cause i will need grip lol
The Plans
-Rb26/30 with Spool imports 3.4L stroker
-Seam welded
-East-bear full cage
-East bear sides and rear bar
-BNR34 Nismo front bar
-BNR34 front gaurds
-Wider wheels hehe
-Custom 1piece tail shaft
-Full Bride interior with bride Gias low-max seats and rear seats retrimmed in bride fabric
-Full Titanium dumps, front and exhaust
+++more
Over the past week i removed the factory sound deadening, and taken the air con out. (it leaked water in the drivers foot well)
Luke
https://www.sau.com.au/forums/topic/280439-r34-gt-four-rb26-time-attack-build/
  • Replies 304
  • 3 weeks later...
Well last night after browsing the jap auctions i managed to find a BNR34 RB26. Came out of a wreck with 70thou k's on it.
Picked it up hell cheap.
Only thing missing is the turbos and injectors.
Been waiting eagerly for you to start this project ever since you told me about it ... g'luck buddy, it's gonna be mad once it's all done. Can't wait to see it on Motorkhana.
Ive fitted up a 260RS brake master cylinder and booster, aswell as a cusco brake cylinder stopper.
Couple pics of the dash and turbos for you guys to.
As for the spool engine, ive just read what they have posted on the forums but nothing seems concrete yet as to release dates. I'll be contacting them when i have some money tho.
Cheers
The cage is a modified cusco r33 front cage and a safety21 rear with a harness bar welded in.
Those wheels will stick out an extra 3mm on the rear. The fronts im not to sure with mine being 4wd the hubs sit closer in im sure.
good luck.
