brief little update.
Havent done much to the car since. Removed all interior now, dash etc
I brought
- 15 Gallon (57L) fuel cell
- Angled filler neck
- Pederson Swirl pot
- OMB peddle box
sorry about the pics quality.
Cheers Luke
  • Replies 304
O yeh hehe, These puppies should supply enough fuel.
Also ended up swapping the 2.5L swirl pot to a larger 4L hehe
Got some parts arriving Tuesday from Japan which i'll update with pics once there here :cool:
Well last night after browsing the jap auctions i managed to find a BNR34 RB26. Came out of a wreck with 70thou k's on it.
Picked it up hell cheap.
Only thing missing is the turbos and injectors.
awsome build mate, just wondering where did you pick up that rb26 from as im in need of one also for my build.
thanks
thanks
Thanks for all the support guys :P
Ive actually got a contact in Japan who i source all my parts through and found the engine on the jap auctions. I actually managed to pick it up with nothing on the turbo side for just under 3k del, which is a bargin :(
Just a couple more parts which arrived today.
Nismo Engine and trans mounts
Nismo timing belt
Nismo front upper arm bushes
Air temp sensor for the intercooler
Coilpack harness
Quick update.
Car is booked into Walker Chassis for July. :blink:
Full weld in cage, Heaps of bars, strut tower bracing, the whole lot. ;)
Got my welder mate coming down in the next couple of weeks to do seam welding, drop tank mounts and covering up the backseat from the boot ;)
Next is All nismo bushes for the rear end and And all Ikeya formula arms.
Edited by Luke_ENR34
Today i decided to start cutting out the rear backseat support ready for the boot to be sealed off from the cabin :cool:
Still alittle more to go, but will finish all the cutting off tomorrow :)
Ive also put the order in for the following:
-Ikeya Formula Rear lower control arms
-Ikeya Formula Rear upper arms
-Ikeya Formula Alloy subframe bushes
-Ikeya Formula Front lower control arms with caster arms
-Cusco Drag rod
-Nismo 1.5 way rear LSD
-Greddy rear diff cover
-Greddy front diff cover
-Hks Twin power
-Nismo full rear subframe and diff bushes
-Du-luck (i think) front and rear sway bars.
Should hopefully all be here within a month. :)
And now im pretty broke :)
Luke
Nice ride dude, love the JDM spec list, i know the feeling of running out of cash serveral times, but hey its all worth it in the end. Keep up the good work, looking forward to the finished product.
Cheers
Benny
Had a package arrive yesterday :P
It contains:
-Nismo Rear knuckle bushes x4
-Cusco Drag rod
-Ikeya Formula Tie rod x2
-Ikeya formula Alloy subframe spaces
Still got another 2 packages coming which should be here next week and the other the week after. Also the fuel cell is basically all done. Just got some seam sealer to put down now, buy some new bolts and get the lift pumps all bolted up.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
