  • Replies 304
  • 3 weeks later...
would the rb26 bolt up to the GT-4 standard 5 speed? how good are these boxes from factory??
thanks
Yep, direct bolt in. The are the same box out of the r32 and r33 gtr, but run the push config clutch. Should be quite tough (as tough as a gtr box is :thumbsup:)
What? Jason told me your car was still in the workshop... sucks that you got defected, though I'm hardly surprised...the car doesn't exactly fade into the traffic with that kind of presence!
Let me know if/when you get it back on the roads and I shall bring my stocko down and have a chat sometime.
  • 3 weeks later...
Jason Nottle, used to be at Minisport, now at ETSA with me, he's building a weapon of a 1600, lime green + SR20.
Had a look over your car at the Extreme Horsepower Show, once again I was tempted to go for a JDM street racer styling lol.
Arr yeh, know him from school.
I'll update this with pics soon but the engine is here as of a couple of weeks ago. Have basically stripped the intake side down, replacing all heater hoses and gaskets. Will be putting the stock engine in just to get it engineered with it in and building a 30 on the side.
Well the 26 Is here and slowly getting worked on by me. Found out it has a nismo clutch and flywheel which wasnt in the description on the yahoo page :happy:
Have taken all the plenum off and heater hoses, which will be getting replaced with Black silicon hoses :). Theres a small crack in the plenum i need to get welded up to.
I manage to purchase a whole heap of stock parts of a member on here, just so i can get it legal with the engine in while getting the 30 built in the mean time.
Parts include
-Stock Radiator
-R34 GTR vspec 2 Turbo's + dumps
- Vspec 2 ECU
- Intercooler
- Injectors
- Piping
Now that the engine is here i have realised just how many small parts i need which will all add up
Havent really found out how hard it is to make it legal yet but will be making sure it is.
Brakes have already been doing to 34 GTR items so im hoping thats it.
i saw you have a carbon boot lip, just a quick one where did you get it and do they make the roof lip spoiler too? iv looked on origin's website but nothing for a r34, any help would be great
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
