brief little update.
Havent done much to the car since. Removed all interior now, dash etc
I brought
- 15 Gallon (57L) fuel cell
- Angled filler neck
- Pederson Swirl pot
- OMB peddle box
sorry about the pics quality.
Cheers Luke
  • Replies 304
O yeh hehe, These puppies should supply enough fuel.
Also ended up swapping the 2.5L swirl pot to a larger 4L hehe
Got some parts arriving Tuesday from Japan which i'll update with pics once there here :cool:
  Luke_ENR34 said:
Well last night after browsing the jap auctions i managed to find a BNR34 RB26. Came out of a wreck with 70thou k's on it.
Picked it up hell cheap.
Only thing missing is the turbos and injectors.
awsome build mate, just wondering where did you pick up that rb26 from as im in need of one also for my build.
thanks
thanks
Thanks for all the support guys :P
Ive actually got a contact in Japan who i source all my parts through and found the engine on the jap auctions. I actually managed to pick it up with nothing on the turbo side for just under 3k del, which is a bargin :(
Just a couple more parts which arrived today.
Nismo Engine and trans mounts
Nismo timing belt
Nismo front upper arm bushes
Air temp sensor for the intercooler
Coilpack harness
Quick update.
Car is booked into Walker Chassis for July. :blink:
Full weld in cage, Heaps of bars, strut tower bracing, the whole lot. ;)
Got my welder mate coming down in the next couple of weeks to do seam welding, drop tank mounts and covering up the backseat from the boot ;)
Next is All nismo bushes for the rear end and And all Ikeya formula arms.
Edited by Luke_ENR34
Today i decided to start cutting out the rear backseat support ready for the boot to be sealed off from the cabin :cool:
Still alittle more to go, but will finish all the cutting off tomorrow :)
Ive also put the order in for the following:
-Ikeya Formula Rear lower control arms
-Ikeya Formula Rear upper arms
-Ikeya Formula Alloy subframe bushes
-Ikeya Formula Front lower control arms with caster arms
-Cusco Drag rod
-Nismo 1.5 way rear LSD
-Greddy rear diff cover
-Greddy front diff cover
-Hks Twin power
-Nismo full rear subframe and diff bushes
-Du-luck (i think) front and rear sway bars.
Should hopefully all be here within a month. :)
And now im pretty broke :)
Luke
Nice ride dude, love the JDM spec list, i know the feeling of running out of cash serveral times, but hey its all worth it in the end. Keep up the good work, looking forward to the finished product.
Cheers
Benny
Had a package arrive yesterday :P
It contains:
-Nismo Rear knuckle bushes x4
-Cusco Drag rod
-Ikeya Formula Tie rod x2
-Ikeya formula Alloy subframe spaces
Still got another 2 packages coming which should be here next week and the other the week after. Also the fuel cell is basically all done. Just got some seam sealer to put down now, buy some new bolts and get the lift pumps all bolted up.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
