  • Replies 304
  • 3 weeks later...
Well after looking around for some rear brakes for mine (was mainly looking for R35 GTR rears or Alcon 4pots) which i couldnt find i decided why not put the 6pots on the rear :P
Which leaves me to these puppies i picked up the other night
8Pot Brembo Grand Terrizmo with 380mm rotors. They are actually all bolt on ready for a BMW X5, So custom dog bones and hats will be made.
You can see in the pics the pad design, its basically 4 small pads per caliper :)
hey luke real good build man, very maticulas (spelling)
i think with the manifold matt mentions in his thread in the FI section that even chinese stainless manifolds flowed 50% more the stock and after porting could only get within 15% of the cheep stainless manifolds, lower half of page 6 i believe this is mentioned
Edited by ahh 33 s2
Sure am mate, Have already been ported out and hpc coated.
Reckon i should go different manifolds?
Are they Unique Autosports ported? I prefer the ported OEM manifolds over the stainless tomei and HKS style as you know. They will give better response and longevity. The 6boost are better again, will make the same power at less boost and less heat...also changed my top end considerably(extra 1100rpm of torque b4 drop off) But as you know they are a pain to fit. It wouldn't be a silly option to stick with what you have. Power wise you will have more than enough to go sub 1:15 without any issue's. It just comes down to how much boost you want to use to get there.
GTRS's need minimal exhaust restriction to punch past 500kw, that's the key. Side pipes are the only way to go. Noise level may be an issue as I did get pulled up on Sat.
Matt
Just got a mate to port them with a die grinder.
Plan to go twin Titanium side pipes (one off each turbo)
Will be good to see how the 6Boost manifolds go over time and weather they crack or not. Thats one thing why im staying stock so far.
  • 1 month later...
firstly awesome build mate
i have the gtrs turbos with external wastes i also had standard manifolds with the r34 dump pipes with 22psi i made 410awkw and was only making power to 7800rpm i changed to hks manifolds and tomei dump pipes and a 3.5inch exhaust all the way through made 449awkw i think u should ditch the standard stuff my 2c worth
Matt
not that easy to make 500kw or maybe the dyno i use doesnt bullshit lol
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
