Hey Guys,
I just got my oil analysis back, I've got serious fuel contamination in the engine oil.
Basically, i need some recommendations on a place in Sydney that can check my injectors (are they leaking?) and other fuel components.
I'm spewing, i put motul chrono in approx 4000 kms ago :blush:
Please help!
M
https://www.sau.com.au/forums/topic/280446-i-need-a-fuel-system-workshop/
Hey mate,
i'm in the bankstown area. I found this place; http://powertune.com.au/ they're close to me, but seems pretty pricey @ $110ph for diagnosis.
A friend of mine encouraged me to get my oil analysed because my oil (motul 300v) changed colour quite quickly ( i dont do many km's in my car ), plus it developed what seems to be a small hesitation at low revs but high throttle... dunno if that's related or not, but he insisted that i should get the oil analysed :laugh: good thing too i guess.
Anyway, i dropped the motul oil, and filled up with some cheaper stuff to get me by, hopefully i can get a workshop to find the problem without costing big bucks
well....prices are heading towards that sort of race at decent workshops, I'm sure you can find cheaper but its not cheaper in the end if they take longer to find the problem. Unique autosports are at seven hills, not exactly next door but probably closer than kirawee.
Interesting results for the oil - did they test for anything other than fuel? I had some checked recently and got good information about the health (or otherwise) of the bearings too.
As well as oil analysis you should get the compression checked, blowby can change the oil colour pretty quickly (as can letting it get too hot of course)
True that!
They tested for water and metals as well... attached is the rundown of tests they did. Their analysis was :
"All wear levels appear within acceptable limits for first sample. Silicon level (dirt/sealant material) satisfactory. Water content
acceptable. Fuel dilution at problem level. Viscosity within specified operating range.
Action: Change oil and filter(s) if not already done. Check fuelling system. Resample 250 hrs to monitor and establish wear trend."
Thanks for the tip, i'll get that compression test done as well
+1 for compression test.
excessive bore wear can lead to fuel going past rings washing the bore walls, then into oil.
if not doing yourself, make sure the workshop does dry and wet testing.
good luck with sorcing the problem
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
