66yostagea Posted July 24, 2009 Share Posted July 24, 2009 I've a blown globe in D/S front parker light. How do you get the assembly out????? so you can replace the globe. There appears to be only one screw holding the assembly in, which screws into the side of the headlight. The assy is loose but something is preventing it from coming out. I dont want to force it. When I got the car the pP/S assy had a broken clip so I dont want a repeat. Any help please. Link to comment https://www.sau.com.au/forums/topic/280495-front-parker/ Share on other sites More sharing options...
MyStag260 Posted July 24, 2009 Share Posted July 24, 2009 I've a blown globe in D/S front parker light. How do you get the assembly out????? so you can replace the globe. There appears to be only one screw holding the assembly in, which screws into the side of the headlight. The assy is loose but something is preventing it from coming out. I dont want to force it. When I got the car the pP/S assy had a broken clip so I dont want a repeat. Any help please. Hey mate, yes its a bugger this one! There is actually a rubber grommet that holds in a male/female type thing... i think if you look in the DIY section there is an instruction, i think i might have done it but can't remember Cheers Link to comment https://www.sau.com.au/forums/topic/280495-front-parker/#findComment-4732198 Share on other sites More sharing options...
kidafa Posted July 24, 2009 Share Posted July 24, 2009 Hugh, Its a matter of removing that screw from the top and then pulling the parkers forward towards the front of the car and the grommet thing pops out. It WILL take some force. Link to comment https://www.sau.com.au/forums/topic/280495-front-parker/#findComment-4732258 Share on other sites More sharing options...
66yostagea Posted July 24, 2009 Author Share Posted July 24, 2009 The force was with me. But what a bugger of a job for such a pissy little globe. And I had to unbolt the guard to get the sod out. Hmmmmmm. Hiroheta's revenge! Thanks for the info. Link to comment https://www.sau.com.au/forums/topic/280495-front-parker/#findComment-4732318 Share on other sites More sharing options...
MyStag260 Posted July 24, 2009 Share Posted July 24, 2009 The force was with me. But what a bugger of a job for such a pissy little globe.And I had to unbolt the guard to get the sod out. Hmmmmmm. Hiroheta's revenge! Thanks for the info. Yeah i hate having to put alot of force on anything like this... ur working with brittle plastic and such u really don't want to be putting all your might into it as when it goes its likely to break something... which is what happened to me as i pulled forwards the mount that has the screw going threw it hit something and snapped... excellent just for a stupid globe. Oh well your done now hopefully won't have to do it again for awhile Link to comment https://www.sau.com.au/forums/topic/280495-front-parker/#findComment-4732803 Share on other sites More sharing options...
