blinko Posted July 24, 2009 Share Posted July 24, 2009 Hi guys, im in the process of designing a project for my electrical engineering class. So im looking at building something like a turbo timer but with many many more functions. If you guys have any ideas on what this device can include please post them and that would be great. The more ideas the better!! Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/ Share on other sites More sharing options...
iamhe77 Posted July 24, 2009 Share Posted July 24, 2009 Boost control Electronic throttle body control with power & economy settings Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4732700 Share on other sites More sharing options...
Jack- Posted July 24, 2009 Share Posted July 24, 2009 Along the lines of a turbo timer, a head light timer with a remote start. Turn your car on at night and the head lights come on, pretty much just a garden sensor sort of thing that measures photons. Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4732864 Share on other sites More sharing options...
Bakes Posted July 24, 2009 Share Posted July 24, 2009 Buit in radar detector Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4732959 Share on other sites More sharing options...
Johnny Posted July 24, 2009 Share Posted July 24, 2009 Electrified bonnet so that when the police go to open it, they get a shock n squeal like a pig. Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4733407 Share on other sites More sharing options...
blinko Posted July 27, 2009 Author Share Posted July 27, 2009 lol good ideas keep them coming. Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4736818 Share on other sites More sharing options...
N1GTR Posted July 27, 2009 Share Posted July 27, 2009 Auto up/down switch for passenger windows Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4737055 Share on other sites More sharing options...
Crans Posted July 27, 2009 Share Posted July 27, 2009 Heres an easy one to add in but could also be very useful. Air fuel controller( Yes like the Apexi one) but make it properly mappable and supprt dual AFM's signal bending is pretty simple Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4737136 Share on other sites More sharing options...
scathing Posted July 27, 2009 Share Posted July 27, 2009 How about a full car immobiliser system, with all the trimmings? Aside from the various cutouts, auto window lifters and turbo timer, how about adding a feature for modern cars and include a fly-by-wire cutout? That way the engine can be left idling with the system armed, but since the car doesn't accept throttle inputs it can't really be driven. It might also legally let you get remote ignition, if you couple it to a speed sensor to re-kill the car if it detects the wheels turning without a key present. You could also fit a system so it'll only remote start the car if its not in gear, to avoid the issues one of my mates had with it and a brick wall in his Commodore. Alternatively, the current fad with a lot of aftermarket parts is for OBDII readers. I'm quite fond of my GReddy Intelligent Informeter. Why not integrate a turbo timer into an OBDII reader? Most OBD systems supply water temp (but not oil temp, as far as I'm aware) and the turbo timer can calculate its "run on" time based on that. Then have it read/display various data, with a peak recording (or even stick in some flash memory so data can be recorded/logged). If you can find out how to read/clear basic error codes from various manufacturers that would be nice too. If you wanted to add smarts to the system, some of the "eco" oriented systems also provide mileage info. OBD will also pull RPM data, albeit with a little lag, so you also integrate a shift light into the display. Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4738562 Share on other sites More sharing options...
Drift_Online Posted July 27, 2009 Share Posted July 27, 2009 Turbo-Timer/Sat Nav, All In One Unit? Link to comment https://www.sau.com.au/forums/topic/280502-engineering-project/#findComment-4738565 Share on other sites More sharing options...
