Hi all :P
i've searched the rectum out of this one, both on here and regular google, but haven't come up with anything... at all...
i went to do a coolant flush on the stag yesterday and i broke that STUPID plastic bung on the bottom of the rad. it's still stuck in there and i think i have buckleys of getting it out, outside of drilling it out and chopping it into little (satisfying) pieces.
is there an alternative to this? the coolant's looking a bit murky so i'd like to get on to this one pretty quick...
i was hoping that maybe there'd be a tap available for it, like with the replacement for the sump?
cheers guys :D
josh
p.s has anyone else had this problem?
Edited by pyro-ns
https://www.sau.com.au/forums/topic/280518-radiator-bung/
yeah, that's my alternative, but i've gotta take the under engine "diffuser" off to get to it. i'm a lazy bastard and i enjoy a bit of destruction, so i was hoping to drill the guts out of that bung and find something better :P
there'll most likely be some sludge in the bottom of the rad too... was hoping to get it all out.
btw, on the neo's, that screw off to the left of the cowling, is that a bleed point for the coolant system?
https://www.sau.com.au/forums/topic/280518-radiator-bung/#findComment-4732693
I had the same thing happen once on my subaru daily. I was lucky because i managed to jam a largeish flathead in there and with enough force screw out what was left of the bung without damaging the thread. Then i just replaced it with a normal bolt with a bit of thread tape wrapped around it to prevent leaks. Sure it means i need a spanner to get it out now but it doesn't leak and i haven't had any problems since! :P Just have to be careful not to over tighten it.
https://www.sau.com.au/forums/topic/280518-radiator-bung/#findComment-4732712
hmmmm, fair enough. i haven't got to munching the thread yet, lol. i've snapped the bit that your screwdriver actually goes into....
this one goes in the shit basket with the top facing manifold, lol.
cheers mate :D
https://www.sau.com.au/forums/topic/280518-radiator-bung/#findComment-4732853
cheers mate :laugh:
Dont be lazy :laugh: take radiator out go get the core cleaned out rodded $100 at radiator joint. I would say if your radiator is murgy sludgy..... the rest of radiator is full of crap and stag radiators are only 1 core(other sports cars 3core) so you want it cleaned properly not just flushed otherwise come summer you risk blowing head and trust me you dont want to fix head $$$$$$$$ :bunny: . especially if your car is modded front mount etc. blocks cooling air trust me the cooling system on rb25 is not something you want to skimp on!!! and dont forget to bleed cooling system, bleeder nut located between inlet manifold and rocker cover.All i am trying to do is save stag owners money in the long run :P
https://www.sau.com.au/forums/topic/280518-radiator-bung/#findComment-4735412
you raise a good point.... the car's still a bog stocker at the moment and we're still babying it until we can get the gearbox serviced and all the tranny fluids flushed and replaced.
tbh, i'd rather sink $100 into a better radiator, lol. i've just gotta figure out where i'd go from here. i'm assuming the 33 rad is an upgrade? maybe just a nore hardcore version of that?
edit:
a triple core 40mm alloy rad from just jap without the gay bung system!!!! :PBJ:
Edited by pyro-ns
https://www.sau.com.au/forums/topic/280518-radiator-bung/#findComment-4735715
edit:
r33 radiator is exactly the same so no upgrade. but bigger ally radiator for r33 will fit no probs and work well . but if your car is auto you will need an extra trans cooler. Stock radiator works fine when not full of shit. My car was not running hot but got radiator cleaned out and new top tank and cap for $150 sweet . the radiator guy told me it was 50% blocked! The main prob is in japan they are reluctant to put coolant in cars.Removing radiator only requires 10mm spanner and large pliers 4 the hose clamps. there are no bottom bolts just 2 top 1's and and 2 self tappers 4 the shroud. would not worry about the bung to much as long as it does not leak.Replace hose clamps with better 1's(screw driver type) then it will only take 30 secs to dump fluid the next time. piss that bottom tray of as it only gets in the way. takeing radiator out is only a 5 min job!!! Best o luck :laugh:
https://www.sau.com.au/forums/topic/280518-radiator-bung/#findComment-4736007
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
