Black cluster. (S1)
No dimmer control. Lights piss weak.
In my R30 you can control the power windows AFTER the ignition has been turned off. That was the crowning glory of the R30 and why I have had four of them and still have two.
Arm ripping location of oil filter. Now have relocation.
Apart from the above the Stagea is PERFECT.
https://www.sau.com.au/forums/topic/280542-the-bad-bits/
i take it this is going to be similar to the good bits thread?
if so:
The STUPID top facing intake manifold - Lets make the most basic of all service procedures take 15 times longer.
The plastic bung in the rad that requires a screwdriver to open *facepalm*
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4732972
S1 auto not tiptronic
all turbo's across the range C34/M35 should have been garrett gt3076-spec from factory
S1 ecu modifiable without the need for a 48pin-84pin chip adapter to house the remaped chip
S1 and S2 should have had silvia s15 JDM 450/480cc injectors standard
S1 and S2 swaybars should have been thicker
think thats about it, along with the above comments
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4732989
Yep Tangles but was thinking more along the lines of generalities in design, rather than performance.
If you throw ten grand at a Stag it will go like a 911, but the effin windows still wont close unless you turn the key on.
Why did Mr Nissan do away with this feature?????
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4733078
I know, and I still reckon the Stagea should have come with a bigger turbo and definately fatter swaybars
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4733311
Wing mirror and front shock towers prone to rust.
Cost of manual centre console ($2k or so, if you go genuine)
sun visors that look like crap as soon as they're a few years old
weather strips that break easily and are almost impossible to get replacements for.
no bi-fold console lid in S1
Dayz side skirts always seem to go misshapen near the rear wheelarch
That said, I always found my (S1) headlights to be very good, and I didn't mind the standard seating position (but my recaros sit a little lower, and it is significantly better)
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4733452
front guards under wing mirrors and front shock towers prone to rust.
Cost of manual centre console ($2k or so, if you can get one)
weather shields that break easily and are almost impossible to get replacements for.
Dayz side skirts always seem to go misshapen near the rear wheelarch (end cap pops out)
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4733453
if it's design faults you want, the clock on the dash is further away than it should be and there's not many practical spots for gauges, lol, although i doubt that's what they think of when they're designing a car :laugh:
!!! i thought that was just ours! the wife's stag looks like somebody's just stuck a dayz kit on it (missing the rear of it though) and i thought it was just poor fitment, haha.
Edited by pyro-ns
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4733533
Already mentioned, but:
+1 on the window controls
+1 on the door rust
+1 on the dimmer (or lack thereof)
+1 on the oil-filter location (and subsequent farkin mess...)
The biggest problem is that Nissan never imported them here, so we've all had to wait 5+ years to get hold of one...
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4733812
stupid rust on strut towers
not enough leg room
no remote start on manuals (dumbest f**kin idea ever)
shit hack single core radiator (slack f**ks )
wtf doesnt it have 4 pot brakes standard ( i have more power standard and more weight than a skyline so why the 2 pots)
space saver that is too small and upsets atessa
odd ball standard tire size on 17s on rsfour s
stupid f**kin hicas rack that the motor points straight down under the diff and gets ripped off when a 33 gts25t one bolts straight on and is way up out of the way
front sunroof doesnt open f**k all
they way my enging runs 10 psi standard but they havent tuned ecu f**k all so with an exhaust and intercooler and the boost turned down so it still only runs 10 psi and it runs rich as and pulls timing
back seat base is nothing more than a big wad of seat shaped foam
no factory oil cooler (r34 gtt got one . wtf didnt i )
thatll do for now
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4734196
not enough leg room
thatll do for now
Good thing this is a car you like, I'd hate to see the list for a car you don't like... :down:
  • Like 1
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4734217
not enough leg room
thatll do for now
Tell us how you REALLY feel! :rofl:
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4734379
Bad bits?
RS boost gauge failures.
OE turbo exhaust wheel... poo ceramic doesn't last!
That is all.
Yes it does. If you want to flog the guts out of ANY vehicle, it has to be built to suit your bent.
I drive pretty hard on occasions. But there is a big (mental) difference between a hard (on) and a flog.
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4734516
thatll do for now
I must respond :P
The brakes are as-per C34 Laurel Sedan, but I agree that with the wagon platform, they should be bigger.
The Series 1 has an oil cooler (adjacent the filter), doesn't the series 2 have the same setup?
And, The S1 trans cooler is a bit piss-weak, but I'm sure it's fine in Japan :)
https://www.sau.com.au/forums/topic/280542-the-bad-bits/#findComment-4734818
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
