Hi guys,
Battery went flat a few days ago, battery is about 6 years old as it is an 03 model. Battery cells were gone.
Had the battery replaced. Went to the petrol station to fill up about 3 km's down the road. Locked the car then unlocked. Went to start the car and the rpm's went up as normal then dropped which lead the car to turn off. Oil, battery and engine light came on. Second attempt same symptoms. Third attempt turned on however this time the rpm completely dropped just above 0 then all of the sudden went back to 700rpm drove off as car was running. On the third attempt it almost sounded like the car wanted to turn off. Got home locked the car and left it locked for about an hour, i again attempted to turn the car on same thing engine turned on, rpm dropped all the way and turned off.
Please help my auto electrician does not know what is wrong with the car, it is the first time he has worked on a car like this.
Kind Regards Yianni
https://www.sau.com.au/forums/topic/280543-2003-350gt-coupe-starting-problem/
Hi Chris not to sure.
I have been doing some research on a few infiniti websites and sourced another person that had the same problem. He referred to the procedure on how to reset the ecu, throttle pedal release and idle air volume learning and it seemed to have resolve his issue so i might give that a go. Its definitely not an immobiliser problem as for starters the car would not even turn on. Apparently the battery of the car was disconnected overnight so it reset the ecu however the auto electrician didn't teach the ecu which regulates the idle etc.
Edited by T88turbo
hey guys this might sound realy stupid, though i had the same problem, and it wasnt my ecu or battery... it was acutally my spark plugs..... when was the last time u checked your plugs? see if there is any oil getting to these plugs, if so see a mechanic.
Nope plugs were replaced 2 months ago.
It only happens on hot starts, its all normal when the engine is cold. This is because when the engine is hot it does not need to rev high, revs drop instantly to about 600rpm as normal.
Stuff it im going to take it to nissan, i bet you its the ecu that needs to be programmed. Remember the ecu regulates the idle, and a thousand other things. I tried this procedure on the infiniti website that resets and teaches the ecu but it didnt work.
Here is the link if you need it.
http://www.nicoclub.com/articles.php?id=356397
Now that you mention it, my 300gt has been doing this as well..
On hot starts, revs drop really low and on a few occassions stalled. Most times, after starting, I just rev it a little and its all good.
has never stalled on me when actually driving only when starting the car. Might have to look into it a bit more.
thought about the fuel type you have been using?? i have another car that has trouble starting when i use shell fuel. BP and mobil have been fine. friggen italian cars! lol
it might be as simple as that for you
hi bilistic,
Did you have your battery disconnected more than 24 hours? I can understand the ecu learning your driving habbits however how does it learn not to stall on hot start ups by reving it are you sure this worked? and did it stall at the beginning when you had your battery changed? I can't understand why it doesnt stall on cold start ups???
hi bilistic,
hey mate
yeh i had my battery disconnected for over 1 week when i installed the plenum spacer (long story lol)
when i finished the install i reconnected the battery and i did an ecu reset straight away before i even started the car again
the car started fine and i took it for a 20min test drive for the ecu to start learning again. i got home and parked the car. i had to move the car again after 5 min and when i started the car - stall.
It kept doing this for about 1 week. Cold starts were always fine. Any start where the engine went into cold start mode (higher revs than normal) it didnt stall. When it was hot (example, went to petrol station to fill up, turn on car - stalled) the car stalled. To get around it stalling, every time i started the car i just blipped the throttle to make sure it didnt stall. I was doing this so, that like you i was going to go and get it checked out.
However, after about 1 week, the problem went away. now i can start my car and its like back to normal again.
Hope this helps.
I use BP Ultimate 98 Octane all the time since i have had the car, and the previous owner did also.
Edited by BLISTC
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
