They will allow you to dial in your cams.
On a R33 GTSt, BOOSTD got an extra 13rwkw at peak, with alot more midrange (up to 20ishrwkw from memory) plus boost started 200rpm earlier. He had 253rwkw when he put it on, 266 when it was set.
I have seen them for as little as 150 for a set second hand, but they are rare to see. New over seas they are around $150 each for HKS (www.greenline.jp), here in Aus, as mentioned $220 - 250 each.
https://www.sau.com.au/forums/topic/28057-gtr-hks-cam-gears/#findComment-585587
SIR33 as Steve mentioned they can be purchased quite cheaply through greenline especially. I have however heard stories of the HKS items suffering issues with the teeth breaking - for the minimal price difference you may be better going for JUN / TOMEI etc alternatives.
https://www.sau.com.au/forums/topic/28057-gtr-hks-cam-gears/#findComment-585592
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
