Hey guys new to skylines australia but not to the scene, have been working on my car for a few months now just cleaning the underbody and getting everything back to either 'clean' or 'new'
Most recently did the RH front wheel arch incl calipers etc and re roadsealing just after some opinions from people to see if you think it looks good or tacky? Let me know
BTW, its not just a quick spray over job, everythings been individually degreased disassembled, sanded back then resprayed properly.
Edited by karmine-ent
https://www.sau.com.au/forums/topic/280587-rh-front-wheel-arch-tidy-up/
looks really good if you ask me. can i ask what you used for the black on the plastic? i have used some stuff in the past but was thick like tar and a pain to apply.
i personally think the worst thing on a car is when you have nice wheels.. whatever they might be and during the day or at night when you get the headlights shining through the wheel.. all you can see if brown dirt and crap that accumulates from driving over the years. when its nice and black it all looks fresh and new and clean under there.
Thanks guys, for the plastic i just degreased then sprayed matt black and used 'septone' body deadner from super cheap auto on the arches seems to be alright.
I got the idea from my mechanic when he put it up on the hoist he said this is one of the tidiest 32s hes ever seen and im lucky to not have a rusty one, I thought I might as well make something good 'better' while its off the road. Hopefully when its all done soon ill get more pics of the underbody. It doesnt cost much at all to do this its just the hours of labour
Cheers guys. Yeah 2 days...I havnt been completely honest it was more like 2 afternoons haha at best 9 hours work but could be done in less time with a simple degrease and spray/paint just to achieve a result. Im just a bit anal, will get more pics up as they come
  • 3 weeks later...
Hey guys been pretty slack lately ive finally got the whole front underbody section done though and its looking pretty spiffy underneath. Its taken a while and believe me its not the best fun under there with grease and dust everywhere and limited room to manouvre anything but im making a little progress...Heres a couple of pics
What you think? You can see where ive stopped with the road seal, im about to start on that area back today
Thanks mate, pretty happy with how its all coming up, looks great in person. Slowly getting down the the back of the car will get pics up as progres comes.
Just a general question, Im in the market for an R34 gtr, so if one comes along I may have to sell this, just wondering what sort of interest there would be in a car thats had this sort of work done to this standard? Any comments would be great, what sort of money would you pay?
  • 3 weeks later...
brilliant man! the work many neglect is the sign of a true perfectionist and to the not knowing eye, it screams tidy for sure no matter what angle. Its amazing what blacking things out and refreshing body deadener etc can do.
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
