Vic Hoon Blitz Friday Night
97R33MSPEC
 Share
just wondering if anyone else got pulled over in the SE suburbs of Victoria tonight with the recent blitz that the police are running. i went to knox city and as i entered the complex immediately the cops pulled me up for a breath-o then told me they were goin to excort me to the back of knox for a full vehicle inspection.
my car was fine so i was allowed to leave as my car is fully legal, but as we left we went and parked in the carpark and had a chat with my mate who purchased a 180sx today.
while we were chatting nother cop car came (peddit) proceeded to inspect my mate 180sx and dicked him for multiple things. the shit thing is that he purchased the car that same day with a roadworthy but still has to get stuck with a fine and shit, needless to say we are taking it up with the roady joint and if they dont want a huge fine from vic-roads, i think they will probably fix the car quick smart.
i know i saw another r33 there parked on side with no front bar on it and a big frount mount hanging out of it haha
  • Replies 111
best not to go to hot spots this w.e aparently lots of ppl getting done
we didnt even go there to do anything/ show off. we went to pick up my mates missus.
at one point there were (no exaggeration) 4 cars around us for 1 car to inspect, lemme know how that is using the police in a beneficial way for anyone!
i got stopped 3 times while trying to leave and go home but i was fine coz my car is all good.
i saw a white r33 getting done by a cop outside knox city tonight, along with a shit load of terroity cop cars and undercovers around tonight. they seemed to have been in weird areas
^^agreed...dont go and catch the drug dealers just go and hunt down imports....it depends on ur luck really
cos catching drug dealers is exactly what the Traffic Management unit is for.
Hell, why don't we get the ambo's to look into petty theft and the firefighters to provide security on the trains at night while we're at it?
Come off it, everyone knew there was a blitz on this weekend, and that the police even stated that they would be targetting the local spots and suburbs. If you still get caught driving an illegally modded car, then its just either bad luck or not enough thought put into it on your part.
was that out the front of fridays by any chance haha :down:
i went past a cop car with a radar gun, working with a undercover police bike, so they would target both sides of the road at the same time.
lucky i was driving in the morning to buy some new engine oil and my car is prety stock and would only get done for height
aww man.. how m i gonna drive the skyline nowadays! :down: i think its time to purchase a soft exhaust.. but WHAT is exactly considered illegal? i know u cant have a fmic with a pod filter, anyhting else?
i got done at knox when i was about to head home =[ i said to mates i didnt wanna go anywhere that night just home and i get done leaving..
yeah i spoke to the guy with front mount hanging out and no front bar, was on his p's.
few other lines in their, como's, wrxs.
i got done for EPA 99db, and bald tyres which i had planned to get fixed in few days. + $190 fine on top of it.
spewing about the exhaust i love the sound of mine, and theres no way im having a gay silencer welded in.
 Share
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
    • For that influx of Spammers we had I made no pic posting and no PM's for first ten posts. This is group based and I've manually updated @Beanie to the Members group which will open up the images and PM's.
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
