Hey Guys....I figured I may aswell throw this up here....cause well Im bored
After much discussion and thought I decided I'd give MRA a shot - http://motorracingaustralia.com.au/
The car will be pretty basic as I just want to go out an race rather than spend the next 2 years building the car.
So here's a basic run down on what the car has now.
ENGINE:
Standard Internal RB25DET
Stainless Exhaust manifold with 38mm Ext Gate
KKK K27 Turbo with a .6AR exhaust housing (its tiny)
Greddy Copy Plenum and standard throttle body
3" Mild Steel Turbo back exhaust
Suspension:
Tein Super Streets
Adjustable Rear upper Arms
Adjustable Caster Rods
I was going to change the Super Streets for somthing a little more track orientated, But I remeber the Success that the Mark Berry / Russel Newman 32 GTR had running them, so I decided to leave them.
In the next week or two I'm going to order a Bond Mild Steel Half Cage (MRA regs require a CAMS Spec Full cage) So I will have the rest of the cage finished off before the 2010 season starts, and once im game enough to hack into my dash for the cage
Im pretty sure ive got a fixed back seat sussed (sparco Sprint V) just going to have a sit in one before I make my decision.
Im yet to decide on what ECU I will use...Sold my PFC Pro when my old engine went POP, DOH!...considering just getting a Toshi Re-map
Injectors will probably be S15 SR20DET 450cc Jobbies as im only aiming for 250-260rwkw on this motor.
Any way enough rambling time for pics.....
Heres how it sits at the moment.
Engine Completed
First Start
And my surge tank.
Ill Have some more pics later today :down:
https://www.sau.com.au/forums/topic/280635-zebras-2010-mra-gts-t-build/
  • Replies 340
Posted Images
post-16947-1248648555_thumb.jpgStevo- was thinking last night that once the car is a full track bitch that its gonna cop a VQ30det, all alloy 3L V6 Turbo with a GT3076 hanging off the side :angry:
Also does any one know if 33 GTR rear sway bars will fit the gtst?
I know the front wont.
Heres a few more pics...while im waiting for the tow truck to arrive
And Here is the reason for this new engine....
post-16947-1248648555_thumb.jpgStevo- was thinking last night that once the car is a full track bitch that its gonna cop a VQ30det, all alloy 3L V6 Turbo with a GT3076 hanging off the side :P
thatd possibly be the worst thing you could do to that car. Stick with the RB25/RB30/RB26
The cost to change the engine over will outweight any benifits and there is far better support for the RB engine than the VG.
You have to remember your trying to build a race car. The simpler you make things the easier it becomes. Go stuffing an engine into a hole it was not meant to be in and your asking for a world of pain.
Custom parts can't be found easily at the race track. Atleast with an original engine there is some hope of getting the right parts when something breaks from a repco or supercheap etc.
If your prepared to carry a mirrad of spares around then go for it but really there is nothing wrong with the RB and id forget the VG idea before it even gets off the ground.
she'll be a while off yet before I decide what to do....havent even driven the car with this engine on the road yet lol...although i did scare a little kid and his mother driving out the driveway to the tow truck this morning.....zero exhaust and 3000 revs FTW haha
shouldnt have to decide. Drop the V6 idea before you even begin.
Id considered it a few times over the years and never done it for a few very good reasons. Money not being one of them.
The RB works perfectly in the chassis
Transmissions are cheap and easy to get for the RB (try buying an upgraded VQ tranny for a decent price)
No custom one off parts that might fail and cant be replaced at the track
Single sided exhaust system keeps thermal management to a minimum and also weight
Plenty of off the shelf parts for the RB, bottom ends etc are so cheap and easy to get (again price a VQ)
Management is simple and easy to get
Not to mention the outlay to have things made like tailshafts etc etc.
My oppinion is that youd spend a tad over 10 grand converting to a VQ roughly. That 10 grand would more than cover a decent dry sump system for your existing RB and also cover alot of the rebuild parts you'd need to make it sturdy.
Also saving alot of headaches and drama come time to race it and break it.
Just my oppinion. Like you say long way off but id be changing direction now.
I considered using a VQ40 pathfinder engine in my current GTR but gave the idea away and went back to the old faithfull RB26. There is just no reason to make the change in a chassis that works so well with the RB
Yeah fair call....mmm dry sump.
I know what you mean about bottom ends been cheap....my "race" bottom end cost 200 bucks lol and has better oil pressure and less blow by at idle than my old built motor ...what a sack of crap that was.....biggest waste of 6 grand ever
i hope its good...its on the car now lol
yeah im gonna see how this turbo goes with the little exhaust housing (was on B-mans Fj20 before i bought it) if i dont like it, the bigger .9 ar housing is about 400 bucks.
But im told this turbo made 312rwkws on a rb20 so we should be good for my 250kw target.
Rb30 would be nice though...might have to have alook at the local wreakers
ahh don't worry about the motor Andrew it is the least of your issues. just get something bolted together that works, get it tuned up....then turn it down 20% for safety and mid range pull.
then....start on all the stuff that adds up but makes a much bigger difference than outright power....
bushes
shocks
springs
brakes (F&R)
diff centre
safety gear (seats, harnesses, cage, kill switch etc)
wheel alignment (including testing)
wheels
tyres
tyres
tyres
tyres
you get the idea
I know you've got a long way to go yet, but unless your budget is "ample" stay away from stuff like cusco. It is top shelf quality with a price to match.
Instead....head down to just jap and check out what they have :P
