whats the 910 for? are you using it for a lift pump? you will need at least two if you are using it for a main pump.
will you make anzac day or is it too soon?
ool, thanks for that Matt :)
Well 2 Dunlop Slicks turned up at my work yesterday :laugh: Thanks to a Mr John Pelingon
aswell as a Bosch 910 External fuel pump and bracket, So im sorting out fuel lines and stuff now...might have to modify my surge tank though as the 910 has a 13.5mm feed fitting and my surge tank is 3/8 from memory.
So now im just waiting on another SAU NSW'er to sell his rims so i can grab 4 more Dunlop slicks.
So really all I have to do is tidy a bit of wiring, dry-ice the interior and mount the harness and ill be out on track:
Oh that reminds me...does anyone know of a bolt in Harness bar for the skylines?
Thanks
Andrew
  • Replies 340
Posted Images
Dammit, Dont say that..i was under the impression that the 910 would flow enough for what i need.
Might have to get a 2nd one then :)
Unsure on Anzac day atm ill be at wakefild the day before marshalling for MRA.
I will let you know asap though :_)
Isn't the 910 the new 044? If so on pulp it should handle it fine.
  • 3 weeks later...
A New toy turned up today, Thanks to stevo :P
Also going to play with the car a bit on the weekend, going to make up some ign coil mounts, and buy some ign leads to suit the holden v6 coils ill run for a little while.
I may have a chance to look at the harness mounts.
Plazmaman make a good looking water to air kit
I'm using one on the supra when I get around to modding that. I'm looking forward to stable inlet temps! Also I'm a huge fanboy of throttle response so reducing intercooler pipe length can't hurt that at all
I don't actually, if memory serves me I had to get one from a computer store, or maybe microtech direct. Hard to remember that long ago sorry
I like the plazaman heat exchangers better though, but for the price difference it's probably not worth the effort and expense of mixing and matching kits!
I've just had a big look around the house for it, definatly not here
the plazaman ones look like the heat exchanger has a better design and better sizes, also their pumps look really, really good
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
