  • Replies 340
Posted Images
lol flux capacitors.....one day mine will see the sunlight again.
stay away from the cheap willwood callipers they are poor quality and flex like crazy. obviously their expensive stuff is as good as anyone else's expensive stuff.
the only brakes i would spend money on for a budget build are the ksport/d2/g4/whatever 8 piston ones. I have 3 sets of them on different cars, they are excellent
Thanks Dunc :(
Ive never seen the cheap Wilwood's up close..they look ok on paper...but that doesnt mean much these days lol.
I forgot about the club crane...thanks steve :(
Im gonna pull the motor down on the floor, it will be easy enough to get a bare block onto the stand once its being decked and hot tanked.
Linton - you need a new partner lol :ninja:
I forgot about the club crane...thanks steve :)
Linton - you need a new partner lol :(
haha... nah shes alright :cool: ... i forgot to add in that little story, that the lifting strap i was using i nicked from work... and it was in the "do not use" box with a danger tag on it... and the carport roof was under a little bit of stress with a 200kg RB swinging around... so... she was the smart one and stood well back..
she doesnt bat an eyelid to any of my stupid ideas... like taking a perfectly good, registered and driving r32 off the road for 2 years to completly ruin it and make it an undriveable cop.
to get my engine off the stand and onto the back of my ute... i wedged a support in under a beam in our carport (35x70 non structual pine), threw a chain around a couple of the joists and and lifted the engine with a block and tackle... backed the ute under it and lowered it down onto the back.. it took all of 3 min and no dramas... the carport was stressing a little, but nothing major, it was all over in a short period.. i removed the stand attachment while it was on the ute...
im sure you could do this in reverse.. bolt the stand attachment on to the engine on the ground... then lift it up and slot it straight into the engine stand.. take 2 secs.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
