only 2 people, thats a fair effort :P
It went in with two of us as well... Poor car sunk in the ass "just a bit" lol
good to see you two got it out.
As for crazy fun, try standing a trailer on end. One personpushes motor against trailer while the other pulls the drawbar back down... Voilà loaded engine!
  • Replies 340
Posted Images
Didnt get anything done last night...cbf doing it with spanners lol.
But i did discover the motor has being rebuilt at some stage as it has .5mm oversize slugs in it, they look to be pretty good quality (better than the cast set I bought a few months ago).
Fingers crossed they are forged
if the pistons and bearings are all good just balance the thing and get the required modifications made, stick it back together with new oil pump, water pump and bearings. if/when it breaks go for the forgies as its not going for silly power.
needs new bearings as matty killed them lol,
I have a set of new rings ill throw in aswell
oh does that mean it already has all the modifications done to the block? that thing will be cheap and fairly easy to get going then. if you need anything machined on it talk to greg at pro engines, he is about 5 mins from your work and knows his RB30's.
It was my original 30 block, it went rattle rattle rattle... Quite loudly!!! Could be easily heard 100 metres off... Lol
told 'drew he could have it if he wanted to take it in as is cons as I was unsure of crank condition
Yeah thats what Im hoping for :ermm:
Im always chatting to Greg about stuff lol
mmmmmm. anything that is x matt is going to be well used lol. rattlle rattle is bad Matt lol. :(
time for chev me thinks.
From the call I just got... There's is supposedly "shavings" of metal through the motor... Lulz
I dont have pics atm but who ever did the machine work on the crank should be shot!
They drilled the crank to balance it...but punched a hole through the side of 2 counterweights! and didnt bother to clean up the large metal shards...so i could just rub my thumb over them the chunks of metal would come off.
also found cracks in the ring lands on 3 pistons and the rods look junk due to the same dodge machinist.
Ill get some photos of the thrust bearings aswel, because I lol'ed when i could move the crank back and forth 5mm.
So Im up for an entire rotating assembly for an RB30, might be a while before its done, but it will be done well
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
