  • Replies 340
Posted Images
Hahahah yep, good thing with the microtech is that its quite simple, no VCT wiring, No AAC valve, etc etc, so its just injectors, ignition, fuel pumps and the CAS, although I have heard that the altenator needs to be hooked up to the dash light otherwise it wont charge....that sounds like an old wives tale to me though, guess I will find out
Brake lights are easy, headlights will just be a switch on the dash same with wipers
Charcoal cannister is long gone lol, just gotta remove the lines now. I thought about no booster, but my knees are fubar, and i sometimes struggle on track with the booster, so non assisted brakes are a no no.
I'll find out for you in regards to the alternator... I'm being lent some top secret information that should have that in it... :P
I havent heard of anyone having much success without the booster. A few people that weve raced with have done it and then reverted back.
You will save a fair whack of weight too. There is so much useless wiring....
The only people I've heard of that have reverted, haven't changed the brake pedal ratio.
I'll find out for you in regards to the alternator... I'm being lent some top secret information that should have that in it... :(
A light is required as it is used as such to turn the alternator on.
A small dash globe in a pilot light is what I use as its enough to do the job. An LED can also be used but it must be used in conjunction with a resistor otherwise it wont charge initialy when you start it. I have used LED's by them selves but its not perfect.
the wiring is easy for the alt itself. the 2 pin plug that goes into the back is has a diagram on the alternator that should show S / L the S needs to have a battery feed and the L needs to run to one side of a pilot light and the other side of the pilot light needs to be switched on by the ignition. key on light comes on. start engine light goes out.
also you will be grate full for having the light down the track when the alt shits itself you will know straight up.
That is possible, though some went to an aftermarket pedal box, which no doubt was different to standard (but possibly not correct, or maybe was, never got into that detail about it) and said the braking/pedal feel wasnt as good as standard. No suprises there. However, I cant see it being as good as the standard assisted setup. Seems like more a space saving/minor weight saving thing to do, rather then something that will actually kelp you go faster around the track....
But each to their own :( Lol though maybe qld'ers cant work it out as well as you nsw'ers.
Exactly. Change the pedal ratio and size the master cylinder properly for a setup without assistance and it works okay.
You will bend tr firewall and pedal bracket if not reinforced well.
Hence why most atleast buy an overhung pedal box with a 6.25 pedal ratio.
It's not as simple as relocating the pivot pin to change the ratio either. The pushrods needs to remain square to the rear of the master cylinder so there is some stuffing around with cylinder mounting.
Well worth the effort of going non assisted.
Who ever was doing that pedal box had no idea how to set it up properly. A well done system will give you a far superior pedal feel and feedback, it's more consistant particularly when you start left foot braking, you gain proper bias control and the pedal can be styled to suit anyones driving habbits with the right masters.
It took us a while to get our heads around master sizing and so forth but done right they are worth it.
Edited by Risking
I use tilton products as I have an awesome supplier for them. In a skyline we use a steel twin pedal hung box. by the time you factor in the two pedals, the mounting you need to do ( really needs to hang from a dash bar on a cage) the three master cylinders ( 2 brake 1 clutch) 3 resiviours and hoses etc there is very little if any weight saving.
Using a 3 pedal tilton floor mount in my r34 which is possibly as heavy as factory system if not more.
Good to hear you guys figured it all out. We never bothered looking into it after we hadnt seen anyone else with much success doing it. Plus never had any issues with the factory setup and alcon brakes. It took me quite a while to left brake and get used to the sensativity....But like anything you adapt and get a feel for it.
But I can see how the setup could easily be tailored to suit.
Edited by r33_racer
Awesome :(
That is exactly what i needed to know :D
  • 3 weeks later...
  • 1 month later...
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
