  • Replies 340
Posted Images
How stupid of me, I didn't even think of DC pumps haha
when are you going to buy yours?
Will you hook it up on full time operation or a toggle?
Thermo fan on the heat exchanger or are you going to do the tap into the radiator setup?
I'll get all mine together after the SAU wakie day.
Going to run the pump off the ign switch, and yeah a thermo fan on the heat exchanger which will sit where the current intercooler is...ive also got a 10L water/ice box in the boot, so i'll fill it with ice cubes for short sprints, and the extra water will help keep temps down for longer runs.
Edit: Just thinking that i may even mount the heat exchanger directly in front of the radiator (under the support panel)
Will do.
Well after much thought last night about the dirty 30 build, I decided that it will indeed get a RB26 head, after talking to a few places about getting the damage on my 25 head fixed it would be cheaper and easier to just throw a good GTR one on.
It will probably run twin 2860-5's or -10s if im feeling adventurous, but if funds allow I may go a twin-scroll T04Z or Gt4088, but I could build a spare bottom end for the same dollars.
So if anyone see's cheap 26 parts (manifolds etc) please let me know :)
On the flip side of that, I could just buy a complete 26 and give it a quick freshen up (rings and bearings, crank collar etc) and run with that.
Please help me choose, I know the 30 will make a shed load more low end grunt but 26's rev a lot better.
argh! I cant choose lol
that's alright...I should've asked our IT guy at work when he was here.
I havent look at the Plazmamann ones yet....but im a cheap ass so i probably wont lol
you mean alex? i dont think he would have one kicking about in his car.
do you have a picture of the serial cable you need? 9 pin male to female? male to male? 9 pin to some random connector?
Lol how do you know Alex?
I ended up getting one off ebay.
Not true, my 30 matches the previous 26 rev for rev.
26 used to go to 8000rpm most days, the 30 has a soft limited at 9000 and the way I drive it, it gets up there!
Don't go -10's though, it's too much power for a gtst. When you're racing would you rather wheelspon and heaps of power or a smaller amount but a linear curve of usable power? Also given that Wakefield is probably where the car will do most work, get turbos to match there-nothing would suck more than having a monster sized setup around the hook section that needs the back straight to get some boost up.
The supra guys that do track work are moving away from the 4088's and to4z's for large 35r's and some towards precision billets.
I'd suggest a 3L with rods and pistons, 26 head with tomei 260 cams and dash5's would be a real weapon
Tyre smoke gets teh biartches though lol.
I think you are right about the -10s and RWD though.
Come over and ill take you for a ride in my r32, that will make sure you dont buy similar setup for a rwd car
The tyres on the front are new (with cast tabs), the rears are showing about an inch of belt per side, and ive seriously been easy on it.
What are you doing for brakes?
haha...I'll hit you up next time im up that way.
As for brakes, Im not 100% sure yet, I've been thinking about Wilwood 6-pot forged superlights and 330-340mm rotors (I cant remember what the calipers will swallow. But that will all be sorted out later on, depending on how the standard stuff holds up...my bet is not to well...but we will see...if I hit the tyre wall on the outside of turn 2 at wakie than ill know ill need better brakes :)
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
