  • Replies 340
Posted Images
lol flux capacitors.....one day mine will see the sunlight again.
stay away from the cheap willwood callipers they are poor quality and flex like crazy. obviously their expensive stuff is as good as anyone else's expensive stuff.
the only brakes i would spend money on for a budget build are the ksport/d2/g4/whatever 8 piston ones. I have 3 sets of them on different cars, they are excellent
Thanks Dunc :(
Ive never seen the cheap Wilwood's up close..they look ok on paper...but that doesnt mean much these days lol.
I forgot about the club crane...thanks steve :(
Im gonna pull the motor down on the floor, it will be easy enough to get a bare block onto the stand once its being decked and hot tanked.
Linton - you need a new partner lol :ninja:
I forgot about the club crane...thanks steve :)
Linton - you need a new partner lol :(
haha... nah shes alright :cool: ... i forgot to add in that little story, that the lifting strap i was using i nicked from work... and it was in the "do not use" box with a danger tag on it... and the carport roof was under a little bit of stress with a 200kg RB swinging around... so... she was the smart one and stood well back..
she doesnt bat an eyelid to any of my stupid ideas... like taking a perfectly good, registered and driving r32 off the road for 2 years to completly ruin it and make it an undriveable cop.
to get my engine off the stand and onto the back of my ute... i wedged a support in under a beam in our carport (35x70 non structual pine), threw a chain around a couple of the joists and and lifted the engine with a block and tackle... backed the ute under it and lowered it down onto the back.. it took all of 3 min and no dramas... the carport was stressing a little, but nothing major, it was all over in a short period.. i removed the stand attachment while it was on the ute...
im sure you could do this in reverse.. bolt the stand attachment on to the engine on the ground... then lift it up and slot it straight into the engine stand.. take 2 secs.
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
