Ma lady has an r32 gts4 and i'm wondering if my ecu i'm removing will work on her gts4. I got a bunch of parts i havent used or have upgraded so i might as well make her car a muscle car killer.
yep
but using someone else's remap is a bad idea
who knows what its tuned for or how its setup
could be enough different to make the engine fail
ie lean afrs, expecting larger fuel pump, different afm ramp, different injectors etc
I put 10K with it and i had a drag 4 3/4" intercooler, front facing intake plenum, and .4bar over what the ecu was setup for with atleast 310whp and never skipping a beat (buddies 2700lb Dodge Dart 340ci 4sp got smoked every time so 2900lb skyline must have atleast that). She's gonna be running my td05 16g i'm gonna rebuild, a w alboro 255lph fuel pump i have sittin arround, a properly sized fmic, stock intake plenum and a afc i never got arround to using. She will be using it for pretty much exactly what it was setup for, if the 4wd isn't gonna be a problem then i can't see a problem with it except having to tell her about the octane booster thats gonna make for 80$+ fill ups.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
