Wrecking a 1999 Nissan Skyline R34 GT-T
Here are some of the parts i have to sell, if you think of more just ask about them:
RB25DET Neo Engine - $2500
4-Speed Tiptronic Auto Gearbox – Make an offer
4 x HSD Coilovers - $750
Brake System incl. Calipers, Rotors, Hubs, Pads, Lines, Master Cylinder (perfect for a 5-stud Conversion) - $1500
2 x URAS bodykit side skirts - $250
4 x 20inch Starcorp Chrome Rims - $1500 ($1800 with tyres)
5 x 225/35R20 Tyres - $150each
Rear RH Taillight - $190
2 x Orange Side Indicators - $20
Badges – Make an offer
LH Front indicator - $40
LH Side Mirror – Make an offer
Triple Gauge Cluster for Center of dash (Voltage, Oil Temp, Boost) - $150
Nissan DRV Meter Gauge - $150
Steering Wheel with Paddle Shift - $250
Other parts available:
Diff
Tailshaft
Bootlid & Bonnet
Rear window & wiper
Dash
AC Controls
AC Vents
Center Console
Glove Box
Front & Rear Seats
Seatbelts
Carpets
Roof Lining
Front & Rear Stock Speakers
Door Trims, Handles, Locking Mechanisms
Fuel Tank & Lid
Foot Pedals
Genuine Floor Mats
Stock 6 CD Stacker from boot
Plenty More
Thanks
  • Replies 51
Hi! Does the Air Con Control work? Any buttons that are damaged? Does the Backlight of the Clock work?
How much including postage to Melbourne, Victoria , 3038?
Thanks
Does the motor come with everything for $2500
Computer, loom, Turbo, inlet & exhaust manifolds?
How many k's are on it?
Do you know what it's compression is like?
Was it running well - blowing no smoke, using no water etc?
I'm looking for the piece of plastic that sits on the drivers-side, underneath the steering-wheel - has the coin holder dealie and the spot for the TCS button, etc (Don't need the TCS button though). If that's available - any idea on postage to SA 5025?
  • 4 weeks later...
  • 1 month later...
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
