  • Replies 52
Posted Images
My ceffy's become my daily. Looking into liquified LPG injection. Got a kit stuck in QLD that I've gotta bring down to melb before I can paint it and put it on. Gotta find some hubcentric spacers to bring out my front wheels a lil, and fit a pair of S14 LCA's, steering rack spacers, and S2 tail lights i've got for it.
mines got rb25 turbo on, but doing it all properly, not just slappin' it on, made up silicon intake pipe with some aluminium reinforcing throughout
made up a custom airbox with ducting
chucking on split/screamer for some truck loving
bought some work ryvers, 17's with +35 offset with 15mm spacers on front (rears stick out wicked ways)
chuckin a 044 pump in
should be a mean little 20
Mine just sits in the garage gathering dust. only seem to drive once a fortnight...
Not even worth having really.
Put my new steerin wheel on....Does anyone know how to reset the steering angle sensor??
Stupid Hicas
sitting in the paddock with no engine or box,
waiting for my crank and sump, so we can assemble the engine and get it up and running finally!!
gate wait to hear the turbo spool and gate crack open!
once thats done its onto the body work,that will be another task in itself!
Mines in the driveway with a broken window reg on the drivers door. Got a multitude of parts sitting in boxes but no where near enough motivation to get the jack underneath the car. Also trying to save for a house deposit makes me consider things like selling the cefiro and getting a track only rig.
Stupid Hicas
If you figure out how to align up the steering angle sensor without CONSULT, let me know - I got the same issue with my HICAS being out of whack cos the steering sensor isn't centered properly ;)
mines my daily....thinking of getting rid of the minispool and going back to LSD.....for some reason i always need tyres for the back :angry: . Hoping for something after the tax is done so i can get a remap, malpassi and retune...still hunting that 200kw.....auto trans is still performing flawlessly too
...still got it - it's in the shed.
RB26 head acquired, 6boost manifold, tial wastegate, new gt3076r, plus a few little odds and ends... Car is completely stripped (again) had full cams roll cage welded in which also extended through the firewall to the strut towers and engine bay seam welded... now to get off my lazy ass and get sanding cleaning to paint interior and get sunroof hole welded up..........
all in good time. just need more moneyzzzz
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
