I am looking at having a turbine housing extrude honed and need some recommendations on where .
From a sniff around Specialised Power Porting at St Helen in Victoria looks popular .
Has anyone used them and were you satisfied with the result you got ?
Cheers and thanks , Adrian .
https://www.sau.com.au/forums/topic/280690-extrude-honingpower-porting-where/
I don't think it's such a good idea to get a turbine housing extrude honed. You will disturb the wheel/housing clearance and the turbo will become unresponsive.
I've had inlet and exhaust manifolds and a compressor cover done by SPP. Due to a change in the setup I never used either of these components but I have before and after flow figures for the manifolds. There is no change in clearances with the comp cover - because none of the machined surfaces are touched - only the volute is done.
Also SPP doesn't do twin scroll ex housings.
Edited by juggernaut1
  • 1 year later...
You'd have to call Andrew at SPP for prices as it was a while ago when I got mine done.
As stated in my previous post I never used the extrude honed parts from SPP as I changed my setup and sold the parts off.
Although had my new twin scroll ex housing setup extrude honed in the US (SPP does not do twin scroll housings)....C-Red is just finalising at the moment.
