Hello,
here is my s15 ive been building for a while now,
im planning to run 9 sec passes on pump fuel manual... should do it easily....
my aim is 650whp on about 23 psi
will do 600whp no problems ive been told by my engine builder considering the combo
engine specs
rb26
micro polished and grub screwed crank
block dipped and crack tested, chemically cleaned
new welsh plugs
arp main studs
pauter rods
cp pistons, modified with custom gudgeon pins .20 thou oversize
all balanced and blueprinted
nitto oil pump
ati super damper 1000hp balancer
very very big and polished port job...
cc chambers
arp head studs
edges deburred
metal head gasket
ferrera oversize valves
hks 272 10.2mm lift camshafts in and out
hks step 2 valve springs
jun type b titanium retainers
bronze valve guides
high energy sump to suit rwd
adjustable cam gears
1000cc injectors
greddy rail
sx fpr
all controlled by a motec m8 pro ecu running a m&w 6 channel cdi ignition system with Mercury coils
also has a full race twin scroll manifold, this is a work of art, there are afew pics of it....
also running hypertune plentum single t/b
garrett gt4088r .95 twin scroll turbo, rated at 800hp
sub zero 60mm wastegate from states
sx 1000hp fuel pump...
rb25 gearbox
jim berry custom single plate clutch
modified as end, s15 bare cradle with all r32 gtr bolt ons, diff, stafts brakes arms ect....
brand new respray in lexus pearl white....
car has only done 48,000kms....
hope to see it running in the next 2 months max
Edited by den001
https://www.sau.com.au/forums/topic/280691-my-s15-rb26-powah/
ita actually 4 sale atm, i have a 34 gtr im trying to negoitate with, it that sale falls thru, ill complete the s15 and race this,
the plan is to run 1 gate, 60mm sub zero gate from the states.... ive been reading its better to run the 2 gates but still dont see the major advantage
  • 5 months later...
