I made this CD for my wedding a number of years back.
Some nice tracks.
These are the actual versions I used.
Enjoy my Mix. Its nice music, good Music, soulful - great to drive to thru the Hills on Boost !!
1. Silence by Delirium / Paul Olkenfold mix
2. Greece 2000 by Three Drives on a Vinyl
3. Take Me Away by 4 Strings
4. 9PM Till I Come by ATB http://www.youtube.com/watch?v=Iv9LozuBzsQ
5. Touch Me by Rui Da Silva
6. Heaven by DJ Sammy
7. Toca's Micacle by Fragma http://www.youtube.com/watch?v=itbzv5QH8Oo
8. Children by Robert Miles http://www.youtube.com/watch?v=VCbO-3hjPok
9. Wooden Decks by Cynical Blend
10. Another Day by Skip Raiders
11. Ocean of Eternity by Future Breeze http://www.youtube.com/watch?v=bkvkETSNOZs
12. Hope and Wait by Drion Too
13. Look At Me Now by Jessy
14. The First Rebirth by Jones & Stephenson
15. Adagio For Strings by Tiesto http://www.youtube.com/watch?v=8lOB0my97SA
being for my wedding, obviously somewhat soulful and meaningful to me...
could add another 85. but wont.
enjoy !
Tangles
https://www.sau.com.au/forums/topic/280695-my-driving-songs/
Some beaut vocal & trance tracks. I'll often break out the trance mixes when heading through the hills.
Another remix of Silence that not many people seem to have heard http://www.youtube.com/watch?v=EWdNW7W3k7g it's a bit more face paced than the oakenfold but i enjoy them both.
You've got good taste right there! I like to crank the Above & Beyond TATW mixes while driving through the hills as its just non stop awesomeness - also tend to throw in some Ferry Corsten, Tiesto, Armin, Ocean Lab and everybody in between.
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
