Just wondering whether this is possible cause if you go to: http://www.area-51.co.nz/mod3.htm
They claim they did one but i thought the bonnet cannot close with the RB26 inside. Also if it does work would it be possible for it to be street legal.
Cheers
(If it works it looks like a cheaper alternative to my wishlist of a GTR R34 :P)
https://www.sau.com.au/forums/topic/28073-rb26dett-in-a-180sx-possible/
Originally posted by quik180sx
and with the lighter chassis you would burn all these gtr's!!!!
very hard, not on the street at least, VERY HEAVY wheel spinning with be a big issue, the tyre size, then 2wd vs 4wd...:uh-huh:
never been a big fans of doing such conversion, as they make the car more unbalance. why don't just work on yr sr20det? as the latest speed magazine show a s13 pulling 310rwkw at stock internal. it work out cheaper to mod the engine internal even with those 2.2L kit then do a Rb26 coversion.
Still u could do internal work and get 300+hp easy for the price of shoehorning an rb26 in there. Rb26 are not cheap :P
Plus whenever u put something where its not suposed to be u end up with problems. Well thats what my proctologist told me.
HPI had a silvia from japan with the same very conversion, it was a very tidy article. I would stick with the sr and doing the internals as sujested above, simple because yeah the Initial engine cost is massive, you could buy all the aftermarket parts for the price of the engine then use the money you would spend on the install on the sr rebuild. Once done you get a fresh 0km engine (the rb26dett wont be that), and you dont mess up the the realy good weight balance of the sr20 equiped car.
Originally posted by rbs13
but how easy is it to get 300rwkw and still have something good to drive on the street... WITH OUT doin internals... i would imagine a rb26 would last a hell of a lot longer at these power levels.
well it's all about give up the balance and make it a straigt line ONLY car. As the front is too heavy the car will lost the RWD oversteer natural and understeer a lot more.
btw, what's wrong with doing the internal? look at aust magzine, everyone seems to be proud to have STOCK internal/ bottom end.
u hardly found the engine internal is stock for even lower power car in japan. They usually OVER mod the engine like what the factory does to keep daily reliable.
***Have you driven a car with a RB engine in a sil? If not i wouldnt make such a comment.
*** I doubt it would last very long or be very streetable.
i have OWN a silvia with ca18 and now skyline R33. i am a person who want to put smallest engine on the front to make the car close to 50/50. like meggala's sr20 R32.
well i recommend him to do the bottom end with those 2.2 kit.
i guess after that they should be even stronger than stock RB26.
with tough 2.2 botton end and some head job, it should be alright to push a tubro support 300rwkw and streetable.
btw, will u run 300rwkw everyday on a RWD car??
I have a 180sx with an rb20 and another with an sr... The guy who owned the sr spent alot of money on it (read 15-18,000) and it makes 435rwhp.... To be honest i could never justify spending that much money on a 4cyl, i worked out a RB26 conversion would cost around 11-13000 fitted, plus you can sell your sr/gearbox. From a standard 26 if you really pushed it with the standard turbos you should get 270-280rwkw which is around 370rwhp..... bolt on a turbo and ecu, with a fuel pump an d injectors and your laughing. The weight difference in the rb is noticable, but not what i would call un-balanced!
"Would i run 300rwkw on a rwd on the street??" F*** yes! Its a blast, drive it off boost and you get 420km to a tank, open it up at 80-90kmh with not clutch and the back end just breaks traction and squirms under power, pushes you so hard into the back of the seat! Makes me laugh every time i do it.. Plus you suprise more than a lot of people on the street
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
