Had this spacer made up so the throttle body clears the valve cover. Was going to go with a phenolic material but, the thickness made doing it in aluminum easier. Also picked up some other goodies recently.
solution to the pathfinder transmission shifter placement
  • 4 months later...
  • 5 months later...
  • 8 months later...
I'm also going to a air to water setup. A forward facing plenum would actually be more piping. The car will be used for drag racing and maybe a little cruising so power is the main goal. Also, if you look at the back of the factory plenum there is a significant amount of runner built into it, that is lost when you go to a bolt on plenum.
