This is going to sound like a bit of a dumb question, but here goes
I'm looking to buy a GTS R33 Skyline and have been doing a fair bit of research on running costs (this car is my 18th Bday present, but i have to pay for everything but the car... seeings as i don't earn a lot i need to know how much it'll cost me) Anyways, my mum was talking to a guy who owns a black R33 GTS and he said that it cost him $60 a week on petrol cause he puts in like Premium stuff, (i dunno much about petrol as i'm sure you can tell) He also said that you have to with that type of car, cause the regular stuff isn't good for it. i'm just wondering is this true? Or can you just put regular in it?
I know this sounds dumb but any responses will be appreciated. Thanks.
Sometimes regular fuel can make the car ping.
It shouldn't be too bad running your car on regular (I'm sure alot of people do) Just fill up the tank with premium every once in a while just to be safe :P
I went on to the BP site, and read some stuff about ultimate and then the premium unleaded. Which is cheaper? Im guessing premium, and would this be bad for my car or would it do? Sorry to keep asking questions, it just really need to know. Here's the site;
http://www.bp.com.au/products/petrol/premi...d.asp?menuid=ed
Oh roughly how much more does it cost per litre compared to regular stuff? Thanks.
Regular: around 85c per litre
Premium: around 95c per litre
There is an average of around 10c per litre extra for premium. Over a full tank, ie: 50-60 litres its about $4 difference. I would highly recommend premium only in your r33. The car was built and designed for japanese fuel which is 102 (or therebouts) RON count which is the octane level in the fuel.
Regular = 92 RON (could be wrong??)
Premium - 98 RON (could be wrong)
You cant actually get 102 RON normally so the closest thing is Premium. Running Regular will most likely cause the car to ping and do wierd stuff.
Premium is the key if its an imported car :P
Never run regular, unless your stuck out somewhere!!
Bad for the engine really, the Nissan manual states PULP and they built the damn thing, so theyd know best!
Ive found Optimax to be overrated, just my experience tho, could just be my area, I usually run BP Premium or Mobil Premium, had a shortage lately.. Speaking of which anyone ever ran 7-11 Evolution, theyve got a no ethanol tag, states 98 Octane and is fairly cheap for premium.
Regular usually sits from 92-94 RON
Premium 96- 98
Depends on how stingy your local servo is really.
Hell, if you want some real get up and go dump some avgas in it :P
Dont feel dumb to ask questions, if you dont ask, you'll never know, and isnt what these forums are bout?
Cheers
(nice bday present)
If you are driving a n/a 33, you can probably get away with it.. but have your mechanic tune it for lower grade fuel by adjusting the timing of the engine. Its essential for a turbo, but you might get away with it in the n/a as the compression is higher.
Otherwise for longer life, use premium.
I run 98 - thou whether I run Synergy 8000 / BP Ultimate / Optimax usually comes down to price.
If you have those 4c / litre off then Optimax usually becomes the cheapest.
Just filled up on Monday, normal unleaded was 72.x and optimax was 81.x -4c brings it down to 77.x c / litre! Thats the cheapest I've seen in about 3-4 years! (normal unleaded with coupon being 66 (safeway) - 68(shell))
for those in Melb this site should be your bible (no offense to religious folk) - www.racv.com.au Then click the Petrol Prices! ;) It's basically the fuelwatch site, but since fuelwatch started charging you can still get it free at RACV website :)
in melbourne BP is i think always 8c more expensive... so on a 65 litre tank, your looking at an extra $5.... so if you do 400km a week, then your going to spending an extra $300 maybe a year by using ultimate... if you cant afford that, you cant afford a skyline.
bp ultimate & shell optimax are both 98
standard premium is usually 95-96
regular unleaded is only 91
ive run my line on many of the std premiums & the high level premiums and i found that bp ultimate works best for my car (mainly better fuel economy).
in my area bp is 5c cheaper than shell so that helps
dont use regular unleaded as it will increase fuel use & decrease performance in a turbo 'line
supra - all premium fuels are rated at 96.
Mobil synergy, bp ultimate and shell optimax are 98.
I have too heard that shell buys bp ultimate, then adds its own chemicals, but my ex - gf's uncles both work at bp and they both said thats not true...
the main thing you should be concerned about is making sure your car runs on 98... after all, it was actually designed to run on 100ron..
when at a bp station, the grey coloured 'premium unleaded' is 96 octane, while the gold coloured 'bp ultimate' is 98 octane. all of the individual stations i've been to (not all everywhere, just of the ones i've been to) only sell one or the other. places with ultimate usually have it listed on the big sign out the front.
shell also offers optimax (98) & standard premium (96)
p1r4t8r if the Skyline you're getting is turbo, definitely don't put anything in that is less than premium. If you are getting a non turbo though, i would still use premium, but you could probably get away with regular. who here has a non turbo GTS? what fuel do you guys run it on?
I always run on Premium (Optimax).
It's always a good idea to also keep a bottle of that Pro Strength Octane Booster in the boot, in case you need to fill up with regular and there is no premium around.
Just saved running the risk of ping when you kick it in the guts.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
