Hey Guys
I am looking at upgrading my stock exhaust system on my R34 GTT and have narrowed it down to one of these two:
http://justjap.com/store/product.php?produ...=273&page=2
I've heard good things from both but wanted to see if anyone's got either of these on their cars and if they would recommend them and why...
Edited by vudoo
  • Replies 60
yeh i really like the look of the tip aswell, looks sex!
but it looks like that one has it's on cat? i prefer to get a high flow cat separate like the catco one...
Kakimoto has two mufflers, its still a cat-back exhaust....
wouldnt swap my kakimoto for any other :angry:
wouldnt swap my kakimoto for any other :P
why does the kakimoto one have 2 mufflers? does this affect performance in any way? and why does it look so much longer in length compared to the HKS one?
I'm in the exact same boat! I want the kakimoto regu but where do u source one from? Its listed in Just Jap as out of stock? Anyone know where i can get one from?
might have to give just jap a call to see when they are getting more in, let me kno if you do this
I have not had the chance to hear a kakimoto exhaust (My friend has one for his 350Z on order) but I have heard the HKS on a few local R32's and it sounded rather nice when you jump on it...
had a kakimoto Regu on mine. exhaust tip looked very hardcore (jap racer style) and on boost in the high revs it used to literally scream.
had the muffler replaced by an Apexi N1 as the regu had started to rust/discolour badly (previous owner in japan installed it) which IMO did sound louder than the regu but i think the RB sound was a lot more pronounced with the N1.
I have'nt heard the HKS either but I'm very impressed with my Kakimoto, even at idle it has a nice subtle business sounding burble but does'nt attract too much unwanted attention, it wont wake the non-Skyline enthusiast neighbours unless its wound up.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
