Sometimes when I let one rip, its really loud, people stop and look. Want details on the noise?
No, you probably dont.
But we'll need more info on what this noise is to help you :angry:
Forgot to mention it's a 1994 GTR32.
I cant really describe the sound, but it's screeching to the ears and it's not like the normal/usual belt slipping sound that you get. Probably a mix of screech and grinding sound. It happens once I turn on the A/C. Stationary, on the move, on cold start up, when the car is warmed up - Same noise. I'm sure it's the A/C. But dont know what. The belt appears to be running too.
I havent tried if there's aircon blowing out cos the sound is so loud, once I hear it, I would turn off the A/C immediately.
If the A/C is not on, the fan blows out cold air or hot air depending on the temperature I set it to be.
it is either your compressor clutch/pulley/bearings or the idler pulley making noise....
or simply a loose belt....
iv done a few belt tensioners especially wen ppl remove the splash tray and water gets into the bottom idler pulley....
if u leave it too long, it will go bang!
Bang sounds scary. Is the compressor clutch part of the A/C compressor? Anyone that I can bring my car to get it looked at? I'm totally new to this. Just got the car not long ago.
Cheers,
It's your alternator belt. I had the exact same problem. Tighten it to factory specs :starwars:
It caused the the massive drain on the electrical system.
Thanks!
I guess I will get all my belts checked then. They're supposed to be new. So i guess when I turn on the A/C, the extra load is causing some belt problem to the alternator? i.e. the alternator is working much harder now?
i had this problem, as soon as the a/c was on a noise like the engine was about to explode happened lol,
got my friends dad to come have a look, he gave me a number for an air con guy, came out to me n turns out my
compressor (barings to be exact, no lube, therefore loud noise like metal crunching when it was turned on) had shit its self due to a number of reasons. so had to get a new one put in, along with some bs valve n a regas
Edited by josh_gts
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
