  • 4 weeks later...
what do you need i might be able to whip sumfin up for ya... as for software, um any vector based graphics program should do, i prefer working in photoshop then importing into AI for the vector work.
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-590736
I might be able to help (those in SA)
My wife is a picture framer and they use a Gunnar ?? mat cutter to cut fancy mat boards (the bit between the pic and the frame) They can import vector graphics and have the mat cutter do the work. We haven’t tried this yet as we aren’t good at vector graphic work, and haven’t tried cutting with vinyl
If you can email me a suitable graphic tell me where to get the vinyl at a good price (not a whole roll, just a bit big enough for a few attempts) then Ill give it a go. If it works out OK I could probably get forum members work cut for little more than the cost of the vinyl.
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-606926
hey i can design some vinyls for that... hmmm methinks an SAU vinyl is in order. As for getting vinyls, your nearest 3M retialer is your best bet for small offcuts.
What you need is self adhesive vinyl.
I'm actually contemplating buying a Stika SX12 to do some vinyl work.
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-607333
If you email me your design Ill try and get it cut. It may take a little while over x-mass due to their busy workload and shutting down for a while to go on a holiday.
PS we can also cut mat boards. If you want to frame a picture with a fancy mat, maybe some skyline cut-outs and you place pictures behind these, it can also be done
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-609355
I did my design (simple: logos & text) in illustrator - using a photo of the car as a template. I then simply supplied the sticker-cutter-guy with an EPS that I had scaled to the right size.
Voila - cool gold stickers and 25kw at the wheels :D
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-616462
james... i'm thinkin of buyin a stika 12 or sumfin which allows you to do 1 foot wide vinyls... u reckon i'd be able to pay it off by doing vynils for ppl? Its about 600 bucks or sumfin.
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-616504
  • 2 years later...
  • 1 year later...
  • 3 months later...
If you want a (fairly) cheap program, you can't go past Corel Draw, it comes with everything including Photo Paint, which will do everything Photoshop will do. It also has a lot of photo editing tools just in Corel Draw. It takes a lot of practice to produce good results. (except for the simple stuff). I have run my business with it for 13 years, since version 4, now on version X3 (13). I also have a print and cut machine. Does decal cut outdoor stickers. If anyone on here wants anything done I would charge $80/linear meter at 1330 wide. If you want to see the sort of results that can be achieved , have a look at the Crusty Demons Ute on our website.
http://www.appealingsigns.com.au/Signs%20-...es%20-%2024.jpg
However this takes expert fitting, and also still took 14 hours to apply, about 8 hours of artwork! All done in vinyl though, and can be removed without a respray. All artwork done in Corel Draw.
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-3266371
i run a 1200mm wide vinyl plotter and 2 large format digital printes. so i can cut graphics and also print images etc and be applied to car bodies, Fast and furious style.. :P
if anyone has small sticker they want produced just PM me, or if someone has grand ideas i would like to give it a go. we could work it out
https://www.sau.com.au/forums/topic/28084-car-graphics/#findComment-3271584
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
