well, further developments have occured....which I will post on a bit later, but for now, I have one question that despite searching forums and manuals I cannot find the answer: What is the standard/stock/factory ride height (centre of wheel to guard) on the R32 gtr?
Thanks,
Fraser.
Edited by Phrase
Thanks,
Fraser.
395 mm front and 390 mm rear, brand new. They settle around 5 mm until 60,000 k's then the front standard shocks are stuffed and the front springs wear out real fast. It's not unusual to see them with standard springs at 370/360 mm.
V Spec & N1 is 10 mm lower, ie 385/380 mm, new.
Cheers
Gary
Gary, thank you so much. That puts a whole new context to things. My car is 75mm lower at the front than stock and 55mm lower at the rear.... no wonder I can't get enough castor on the front left to stop it pulling to the left.....no wonder the ride is tiring...etc....
based on this wonderful bit of news, i might be able to get the results i'm after without having to get custom made springs..... back to the calculator....
Thanks,
Fraser.
well, after doing some more sums, I believe I can get close to the ride height I want by using Kings Low springs or Tein STech Springs.
So, over the weekend I have put the car up on stands and taken out the springs/shocks.
Tomorrow they are going to Fulcrum so they can:
- remove the springs from the shocks,
- dyno the shocks to make sure they are ok(hope so), if not i will have them valved for the new springs..
- then fit new springs to the shocks for me.
Which I will then refit to the car then get a 4 wheel alignment.
So what springs I hear you ask? Well, Tein Stech in the front at 3.7kg/mm and King Springs Low at the rear (2.7kg/mm). (57.8/0.422)
I know the STechs only come in sets of four, but I could install in the rear if I want to play with the handling, or i can sell the rears...
hopefully there are no problems reinstalling and the money I saved removing the struts covers the cost of the extra pair of springs.
Will report on progress.....
Fraser.
Disclaimer: this is not meant to be a bashing post.
ok, update: saturday 3 weeks ago i purchased some car stands (repco $30 a pair) and within 2 hours had the shocks and spring out of the car.
The following tuesday I delivered them to fulcrum.
They removed the springs then dyno tested the shocks.
On thursday I rang to find out progress. The shocks tested up well. (woohoo $150 a corner saved), they had ordered the Kings for the rear but were having trouble finding a set of teins for the front.....but they could get some in from Japan....
First Mistake: I assumed that Fulcrum (the Aussie Tein R&D partner) would have stock....
So frustratedly(and smart-arsedly), I suggested an ebay auction that Fulcrum could purchase the springs from, they informed me that they couldnt, but that I was welcome to purchase and have Fulcrum fit to the shocks for me.
So I purchased from Access Autoworks. They were good. Paypal was not. No matter what I tried, the only way I couldve had the springs shipped direct to Fulcrum would have been to change my primary home address to Fulcrums!
So with a couple of attempts, I finally got the Teins shipped....to my home address.....which meant they would end up at the post office for collection.
Last Saturday I walked(remember car is still up on stands) to the Post office and picked up the springs, took them out of the box to put them in my backpack to bring them home.
Second Mistake: Dont use paypal if you want to ship to a third party
There was also a japanese instruction sheet in the box which I did not read until I got home.
I got home and read it. It said: Front 3.7kg/mm check, Rear: 2.0 - 4.0kg/mm ARRRRGGGGHHHHH!!!!
ALL the data I had looked at said Rear:4.0kg/mm ... which is why I bought a set of Kings for the rear!
Not even Fulcrum when I said 'I just cannot believe that the rears would be stiffer than the fronts' had nothing.
Third Mistake: dont trust the manufacturers or distrubitors websites......
So, I am continuing with the Kings in the rear as they are already fitting to the shocks. On Thursday, I will deliver the front springs to Fulcrum.
I did want to share the rant, thanks for reading but I mostly wanted to share:
Tein S-Tech Springs SKN14-S1B00 for BNR32 Spring Rates: Front: 3.7kg/mm, Rear: 2 - 4kg/mm. Which gives 65/35 ratio using 2kg/mm at the rear which is what I was trying to achieve from the outset!!!!!
perhaps I will swap the kings rears for the tein rears.....anyone want to buy a set on kings rear springs? never used!
Thanks for reading, hopefully will refit everything this week.......
Fraser.
  • 3 months later...
OK Gary "SK"
With your spec. Bilsteins,
For Street, Kings low vs Tein S-tech vs Eibach Adj.
What would be your choice?
Is there a difference between hot vs cold wound coils?
Edited by rapidroy
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
