I've inadvertently rounded out the philips screw hole in the idle air adjust screw thingo, which, for those who do not know as I didn't, is actualy plastic, so beware !
I'm looking for the part No as Nissan , though very helpfull , couldn't locate it and niether could I when the showed me the parts schematic, every damn thing was shown except the screwy thingo.
So--anyone know the part No ??
And anyone got any idea as to getting the sucker out ?
Anyone got a spare one they would like to sell ?
https://www.sau.com.au/forums/topic/280881-idle-air-adjust-screw-in-thingo/
call nisswreck I think they have a GTT in stock so they might be able to sell it to ya if they still have it.
Mine doesn't do jack shit ..unscrewed all the way and the car idles the same ... first thought was a vaccum leak somewhere after the butterfly* but pressurizing the whole engine with a smoke machine revealed no leaks.
(* what my mechanic said)
Thanks for that , tried them , no go. tried nissan-t no go and they told me when no part No is shown but the part is present then that part will be part of the larger part which is shown and a part no shown for it. so that means that to replace the adjust screw you have to buy the entire AAC valve set up at around $600.00 sheeesh :rofl: .
So, not surprisingly, I'm still looking.
Possible thought on removing it would be to heat up the end of a flat head screwdriver and push it into the plastic. Might give you enough grip to remove it.
Good thinking ,I'm wanting to clean out the AAC valve so I've got a very small easy-out bit thingo from Bunnings and that should get it whilst the thing is orf, the real problem will be replacing it, I'm thinking of drilling and setting a small self tapper in the adjusting bolt/screw with 222-02 locktight , the only other alternative I can see is to find a same sized bolt and have one turned to suite or cut a groove in the top whilst the valve is out
There's not much chance of doing anything whilst the valve is still in other than what you suggest, and you can just imagine the fun when the idiot thet stripped it in the first place starts playing round with red hot screwdrivers under the bonnet, he he. :rofl:
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
