Hi Guys,
Im very close to finalising the last of my machining for my new engine and have an oil system question. I have built quite a few high performance VW engines and one of the things we do with the oil systems is to use an oil pump that doesnt return oil to the crankcase. Instead it pumps the oil to an external fitting where its routed via a remote filter and cooler. They call this a full flow oil system.
So, ive heard of RB26's that use a deep sump extension with an external oil pickup. The approach would be to dril and plug the engine block's oil pickup gallery and then drill and install a fitting in the pump to allow a connection for the line that comes from the sump. I think this was done on the bathurst GTR's.
Has anyone tried doing anything like this with the output side of the pumps and then returning oil directly to the block? The advantage would be that you dont have to use one of those remote adapter attachments, and the oil hoses would be a bit shorter.
Cheers,
Ian
Edited by GTRNUR
Nothing even close to a dry sump set-up.
Done plenty of the pick up sides but never done it with the pressure side.
I cant see any reason why it wont work the only advantage is like you say slightly shorter oil lines for the cooler and no need for a filter mount on the block.
Its alot of friggin around when the original gallery works fine and filter mounts are not that hard to use.
On a race car I could see some small benifit in making things simpler but for general use I cant see the point.
Edited by Risking
Well it seems I may not need to do this anyway now.
The oil filter block I have sourced had a large metal cylinder with to hose connections on it. If im not mistaken this is the oil cooler attachment with the built in oil thermostat thats used on the N1 GTR's right?
While drilling and plugging galleries might seem like a pain in the ass, ive actualy had that done to all the galeries anyway so I can clean out the block properly. The block has had a lot of metal shaved out of it and I dont want any of that in the oil system.
Yes thats the OEM oil cooler.
Your better off pissing it all off and screwing an oil filter thread straight into the block and doint it RB30 style with the oil filter mounting plate straight to the block.
We dont run those OEM coolers with aftermarket cores as well.
Found they allow way to much oil temp variations depending on heat soak in the cooling system etc.
There is a steel sleeve in the block that normally has an o-ring seal onto the inside of the filter mount.
How do you screw the filter straight onto the block, or do you mean use the filter mount and just dont connect the coolant lines to the oil cooler side of the mount?
I thought of doing that while my motor was out, sounds like a good idea.
You could always get a plate made up with dash fittings for the oil cooler that bolts up to where the standard one does, like a lot of SR20 guys do
You need a double threaded fitting to replace the one with the push over o ring setup which allows the use of the oil cooler block.
Rb30 has this double threaded fitting...
Ah... so that fitting in the block is threadded in and not pressed in then. That makes more sense.
I wouldnt even bother trying to source the adapters new, i tried that and instead raided the rb30 collection (different thread size each end). To get them off the block just go buy 2 half sized nuts and do the old double nut lock trick.
Pic show what i did: Got the sandwich plate from mscn http://www.mscn.com.au/scripts/prodView.asp?idproduct=354 part number TD1014B
yeah getting rid of the standard oil/coolant heat exchanger is a good idea. people do it all the time with SR20. tomei make one as do saurus for SR20. (pics below) you could get something made for RB26 easily enough, there would be a market for it for sure.
obviously the GTR one would look very different but you get the idea. :pirate:
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
